did mine myself. well... my 18 yr old helped alot. took some time and had to go to several places to find the correct size and strengh bolts for the collector flanges. the stk ones are a wierd design and do not work for headers. i think that is the only reason it was a all day event. would have taken around 4 hrs including the hr it took to do the spark plug wires after the install. well worth the time spent on the car. both the sound and the fun and satisfaction of working on the car myself. the mechanics at work could not believe i did it myself. i did have a p0410 code drive me nuts for quite a while afterwards. it is a code for the air pump unit. after numerous attempts to correct it. it finally has decided to take a break from tripping the check engine light.
I installed my headers with the vette on jackstands. Read through the directions a couple times and make sure you have all the tools you need. And if you don't have the tools, buy them and you'll be prepared for future mods.
I did the dynatechs last week and it was very easy. Like said, the last bolt on the drivers side is a pain pita. Other than that, it was easy. Just make sure you have the right tools. I recomend the Dynatechs, because they come with every nut, bolt, and gasket you need for the install. Good luck
This post makes me want headers more, and while not everyone who owns a Vette has alot of money, I would just as soon pay a shop or someone I know to do it with the thinking that if can afford to own a vette you can afford to have things installed. It also depends on how much your time is worth. And then there are those who rather work on their car because that is their hobby and they are mechanically inclined. Just my thoughts on the subject. Headers and intake are obviously a must if you are into performance. Thanks a million for the quality of instruction!
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Originally Posted by devnull
Based off of the posts of yours I have read in the past, I know you can do this...
(I installed them on mine in a few hours, and I am the dumbest SOB here)....
No, that would be the tool in the other thread who curbed his own rocker panel last weekend (twice in the same parking attempt!) and was just happy he didn't have to split an omelette with his wife during the ensuing breakfast as a result!
