Vert Top>>?????
Old Oct 23, 2006 | 05:19 PM
omarcoolguy's Avatar
omarcoolguy
Default Vert Top>>?????
ANY ONE HAVE ANY GOOD TRICKS TO GET YOUR TOP LOOKING LIKE NEW.....I HAVE A COUPLE OF LIGHT MARKS ON IT.....SHOULD I USE A RAG TOP CLEANER???? OR SOME SORT OF ???. ANY SUGG.. ITS A BLACK TOP I WANT IT TO LOOK REALLLL DARRKKKK
Old Oct 23, 2006 | 05:32 PM
VinnieR's Avatar
VinnieR
From: Austin, Texas 2005 National Champs in Football and Baseball.
I've used RaggTop cleaner with good results on my shale top. However, I doubt that it would darken a top unless the dirt/blemishes were what was making the top lighter.
Old Oct 23, 2006 | 06:32 PM
steve8's Avatar
steve8
I'm still waiting (my fault) to use the raggtop kit. Sounds like the best product out there.
Old Oct 23, 2006 | 07:47 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
I heard the same thing about RT and will try the stuff in the springtime when it gets warm again
Old Oct 23, 2006 | 08:47 PM
PaceThis's Avatar
PaceThis
there's a carpet/vinyl dye sold at most auto stores...duplicolor. If you want that deep black, it'll give it to you...I did one in gloss black and it's awesome looking...you'll only want a light mist coat . . .too much and it'll lose it's soft touch...
Old Oct 23, 2006 | 10:11 PM
rws.1's Avatar
rws.1
Before you try dying it, I would suggest you try cleaning it.
Raggtopp or Aerospace 301
Old Oct 24, 2006 | 10:51 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
I've only ever cleaned and treated my top with RaggTop and it works great. Highly recommend it.
Old Oct 24, 2006 | 12:14 PM
99 vett babycar's Avatar
99 vett babycar
ragtop and black shoe dye
Old Oct 24, 2006 | 12:34 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Clean it with soap and water and then use a Shop Vac to suck the dirt out. If it's never been done before you may want to do this 2 or 3 times till the water you suck out is clear. Then use Raggtop conditioner. My .02
Old Oct 24, 2006 | 12:41 PM
jon c's Avatar
jon c
raggtop cleaner and protector is the best........
Old Oct 24, 2006 | 12:56 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
I have a similiar problem with shiny spots on my Black cloth top. It looks like the fabric has rubbed smooth in places from being folded. I've tried various tricks including brushing and misting flat black paint, but they're still noticable. So I'm still looking for a fix.
Old Oct 24, 2006 | 01:47 PM
larryzonka's Avatar
larryzonka
Is Ragtopp good for all colors? I have Oak and I am too embarassed to take out the top.
As far as cleaning with soap and water... any tips?
obviously it isn't good to do it in the direct sunlight... what about
- Soap type, Dove? dishwashing detergent? car washing soap?
- Water temp: warm, hot or cold?
Can I use a brush scruber like a toothbrush or anything abrasive like a brillo pad or steel brush?
FYI - I heard it is good to wait til the top is completely dry before storing it. Is that right?
Sorry for all the questions..
Old Oct 24, 2006 | 02:04 PM
Bingo Fuel's Avatar
Bingo Fuel
Let Me Bignofi That For U
St. Jude Donor '15, '17
Just used the protectant on Sunday after washing and letting dry.
I didn't need the cleaner this time.
After applying two coats (waiting 15-20 mins between) it made the top
look brand new and uniformly darker black. HTH
Old Oct 24, 2006 | 08:16 PM
jon c's Avatar
jon c
my top is oak and I use raggtop with no problems
To Vert Top>>?????
