I have a question for the forum. Very shortly I have to put my twins ( my 75 and 78 ) away for the winter. They are no problem as I have been doing that for approx a dozen years. I have always wanted a C 5 and finally found what I wanted this past August. ( A Pewter Convt with black top and Interior) " Very happy" Oct 1st we took it 5600 kms (3000+ miles across Canada thru the mountains in British Columbia and back. Awesome ride. Now the question. With all these power options and computer what should one do for the winter. I will be stored in a garage but not heated. I have heard that even though everything is turned off, the computer? still draws from the battery. At this moment my plan is to leave battery all connected and simply start the car every couple of weeks. The car will not see the hwy til April 1 Any suggestions would be greatly appreciated./
If you truly do not intend to drive it until spring, disconnect the battery and walk away. You don't do the car any good by starting it every couple of weeks -- it won't get it hot enough to evaporate the condensation out of the exhaust and crankcase unless you drive it to get it fully warmed up.
Either disconnect the battery entirely or get a maintenance charger and hook it up (the kind that turns itself off and on automatically upon reaching a certain voltage - NOT a continuous trickle charger). Your proposed start-up procedure is, IMO, worse than just letting the car sit.
Put it to sleep and wait til spring.
Pull the cables and wait for spring. You'll miss one two week start up cycle and it will be dead anyway.
If you have power where you store it, buy a battery float charger and leave it connected all winter. www.harborfreight.com
AUTOMATIC BATTERY FLOAT CHARGER
Skip the aggravation of a jump-start by keeping your vehicle's battery fully charged. Use on 12V batteries while in storage or during cold weather. The floating circuit maintains a full charge without overcharging. Includes automatic safety shut off.
Leads: 10 ft. overall length
ITEM 42292-1VGA
$7.49
Are you in Canada? ... the Manstore (aka CTC) probably has one, but at the price even with freight and duty the harobr freight option is hard to beat...
I have used one for the last 3 seasons on my 2 Vettes
and best of all no Corvette tax
Here's what I do to mine for winter storage.
- Put a bottle of Sta-Bil in the gas.
- Change oil and filter.
- Put a piece of old carpet under each tire and inflate tires to proper pressure.
- Hook up a Battery Tender Plus to keep the battery in good shape.
- Put car cover on the car.
As usual, I disagree with EVERYONE about the "don't start" theory. I do not like the idea of oil not circulating through the engine, and moistening all of the gaskets and seals, as well as some of the valve springs sitting under tension while holding some of the valves open FOR 3-4 MONTHS, therefore I do start the car every 2-3 weeks and let it come up to operating temperature.
I've been doing this for my winter stored cars since 1976, and haven't had ANY problems!
Another thing to think about is your tires. I called Goodyear last winter and they said that the car should be lifted off the tires or simply move the care a few inches every couple weeks so the tires are not sitting on the same spot for serveral months. I would just give the car a roll forward a foot or so and then back a few weeks later.
IMHO - if you start it you need to drive it not only until the temps are up but until you burn off all the moisture in the exhaust pipes/mufflers.
I have a 68 Camaro with 208K on it. It is my show car. It is never driven if there is a could in the sky. I have for the last 20 years of its life, started it in the winter and let it run until it gets extremely hot. Obviously it does not have a computer, but I still discount the battery..I do that because there is always a drain on the battery and I want it to start without jumping it. The exhaust has not rusted out yet in 20 years.
I love my Camaro, it was my first car and I am the only owner of it. I would never do something to it that I feel would harm it. My 03 vette is a much better car than the Camaro, now if the Camaro can handle this proceedure, then vettes can handle it even better. Yes I know flame on, but this is just my .02 worth.
This what I've done for the past couple of years with no problems (plus I also did it for about 6 years with my '96 LT1 Z28):
- wash and wax
- change oil and filter
- stabilize gas and fill to max possible
- inflate tires to a hair over max
- keep battery connected
- cover it
Every 2 - 3 weeks (during the winter) I uncover her and fire her up and get it up to operating temp. I move her a few feet so that the tires are resting on a different spot (to avoid flat spots). I run thru the gears and "touch" all the controls (including the AC) to "get the parts moving"..
If the roads are dry then I'll take her out for a little spin around the block.
I just don't like the idea of not starting her up for months on end.
Put in 40 lbs of pressur in your tires and all is well. Remember you loose 1 lb for each 10 degrees temp. goes down (assuming a unheated garage)
I have a unheated gararage & stored my Vert since 98 that way & now store my 05 Vert the same way.
I use a battery tender. Do not know what they cost now but paid $16 for it at Wally World Brand was Schumacher <S>
Personally I can't see NOT driving the car once every couple of weeks if the roads are dry. I even drove my motorcycles during the winter to keep things fresh.
Starting it is fine, so long as you get it up to operating temp..I do this, but also take it out and drive it for about 20-30 min. I think just starting it and running it for 10min or so is what most people say is bad.
If you have a battery tender, that is ideal, then no worries on a dead battery.
I understand what you are saying about dry. BUT!!!
In my neck of the woods they put SALT down by the tons. It’s rather corrosive (yes there are parts on a Vette affected by this) It’s also VERY slippery, and remains on the road a long time. after snow is cleared You could slip or slide a bit, but knowing Vette drivers are the best in the world doubt that will happen.
Other drivers not as good could and do slide into other cars. + their tires make a good sand/salt blasting quite probable.
It’s your car drive it as you want, mine is in the garage till April (till all snow is gone and a couple good rains wash all the salt and sand away).
