Column Lock Information Please
Old Oct 24, 2006 | 04:42 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Column Lock Information Please
I have only had my 01 for 4 weeks and I have seen a lot of post dealing with a column lock problem. How can I check to see if this issue was addressed on my 01? Was this a GM recall or is it an isolated situation.
Old Oct 24, 2006 | 04:44 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Start with this post - http://forums.corvetteforum.com/show....php?t=1015483
Old Oct 24, 2006 | 04:48 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
A Chevy dealer can run a check on the vin number, maybe the work was already done on the car.
Chas
Chicago's Avatar
Chicago
St. Jude Donor '15
It's a GM recall. Head out to your car and turn the wheel. If it locks, you need to install a CLB. If it doesn't, chances are the CLB or the dealer fix is in place.
Old Oct 24, 2006 | 05:00 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Post the last eight digits of your VIN and I'll show you exactly what work was done to it right off the GM website.
Old Oct 24, 2006 | 05:33 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
My CLB came in today's UPS and is installed as we speak! Thanks to the confidence forum members gave me in this product I won't have this problem in the future. Better safe than sorry for $50 and under an hours time.
Old Oct 24, 2006 | 05:58 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
I just bought a 04 z51 a week ago! So if i gave you my vin number, you could find out what all has been done to my car?
Old Oct 24, 2006 | 06:06 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Last eight digits of vin 15115877
Old Oct 24, 2006 | 06:32 PM
RichieRichZ06
St. Jude Donor '08
Here is all the warranty history on that car and the CL recall HAS been done.
VIN : 1G1YY22G615115877
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2001 CORVETTE COUPE Warranty Start Date : 04/21/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : MAHER CHEVROLET, INC.
2901 34TH ST N
SAINT PETERSBURG , FL 33713-3636
(727) 323-5000
Selling Source : 13 - CHEVROLET
Site Code : 26424
Business Associate Code : 114755
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 04/21/2001 10 miles 04/21/2004 36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 04/21/2001 10 miles 04/21/2007 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/21/2001 10 miles 04/21/2009 80010 miles
36/36000 FEDERAL EMISSION 04/21/2001 10 miles 04/21/2004 36010 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
11/15/2004 169894 # N0110 - BATTERY - ONE - REPLACE 23320 miles
11/08/2004 169502 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 23287 miles
04/03/2003 141136 # H2505 - MODULE, ELECTRONIC BRAKE AND/OR TRACTION CONTROL - FOUR WH 18106 miles
04/03/2003 141136 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 18106 miles
04/03/2003 141136 # N4920 - MODULE, LOCAL INTERFACE UNIT - DOOR - RIGHT - REPLACE 18106 miles
02/26/2003 139189 # N3214 - ACTUATOR ASSEMBLY - DOOR LOCK - RIGHT FRONT - REPLACE 17388 miles
02/26/2003 139189 # E2320 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - RIGHT - REPLACE 17388 miles
02/26/2003 139189 # Z7901 - 1-DAY COURTESY TRANSPORTATION 17388 miles
02/26/2003 139189 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 17388 miles
05/30/2001 109268 # N5661 - POSITION SENSOR, RIGHT FRONT (ELECTRONIC SUSPENSION (ESC/R 789 miles
05/30/2001 109268 # Z7902 - 2-DAY COURTESY TRANSPORTATION 789 miles
12/14/2000 A15877 # Z6999 - PDI RELATED FLUID ADDS 3 miles
12/14/2000 A15877 D Z6999 - PDI RELATED FLUID ADDS 3 miles
12/08/2000 A15877 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 1G1YY22G615115877
VEHICLE BUILD
Gross Vehicle Weight Rating : 1671 kg (3685 lb) Order Number : CWJD6R
Build Date : 12/08/2000 Build Plant : 115Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
B84 - BODY SIDE MOLDINGS CF7 - REMOVABLE SUN ROOF
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE LOW EMISSION VEHICLE F45 - SELECTIVE REAL TIME DAMPING
GU6 - REAR AXLE 3.42 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL4 - ACTIVE HANDLING SYSTEM JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NF7 - FEDERAL EMISSION SYSTEM NLEV NK4 - LEATHER WRAPPED STEERING WHEEL
N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT QF5 - POLISHED ALUMINUM WHEEL
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1AY - STOCK ORDERS PROC OPTION
1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN 19I - BLACK INTERIOR TRIM
193 - BLACK LEATHER TRIM SEATING 70U - TORCH RED
RichieRichZ06
St. Jude Donor '08
YEP!
Old Oct 24, 2006 | 06:41 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Thanks RichieRichZ06. I really appricate it. This makes me feel a lot better.
Old Oct 24, 2006 | 07:16 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
YEP!
It's 45132024.
Thank you
Old Oct 24, 2006 | 08:23 PM
Z06PDX's Avatar
Z06PDX
Can you point us in the right direction to do this ourselves so as not to bother you?
Thanks!!
Old Oct 24, 2006 | 08:28 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Go to a dealer and get them to enter your VIN then they can tell you
Old Oct 25, 2006 | 10:36 AM
RichieRichZ06
St. Jude Donor '08
It's 45132024.
Thank you
Here you go.
VIN : 1G1YY22GX45132024
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2004 CORVETTE COUPE Warranty Start Date : 08/04/2004
Delivering Dealer : BILL ESTES CHEVROLET, INC.
4105 W 96TH ST
INDIANAPOLIS , IN 46268-1112
(317) 872-3315
Site Code : 25164
Business Associate Code : 112863
Vehicle Has No Current Record Of Outstanding Campaigns
36/36000 BUMPER TO BUMPER 08/04/2004 12 miles 08/04/2007 36012 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 08/04/2004 12 miles 08/04/2010 100012 miles
39/39000 GM CERTIFIED USED 08/04/2004 12 miles 11/04/2007 39012 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/04/2004 12 miles 08/04/2012 80012 miles
36/36000 FEDERAL EMISSION 08/04/2004 12 miles 08/04/2007 36012 miles
CLAIM HISTORY
10/08/2004 013464 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - REPLACE 4175 miles
10/08/2004 013464 # R0942 - SPEAKER, RADIO - FRONT DOOR - RIGHT - REPLACE 4175 miles
06/08/2004 A32024 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 1G1YY22GX45132024
VEHICLE BUILD
Gross Vehicle Weight Rating : 1671 kg (3685 lb) Order Number : HHTPHG
Build Date : 06/08/2004 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CC3 - TRANSPARENT REMOVABLE ROOF PANEL (REPLACES STD ROOF PANEL)
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
FE3 - SPORT SUSPENSION FE9 - 50-STATE EMISSIONS
G90 - REAR AXLE-3.15 RATIO G92 - AXLE: 3.15 PERFORMANCE RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QF5 - HIGH POLISHED ALUMINUM WHEELS
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
Z51 - PERFORMANCE HANDLING PACKAGE: (INCLUDES STIFFER SPRINGS AND STABILIZER BARS) 1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - BLACK INTERIOR TRIM
193 - BLACK LEATHER TRIM SEATING 41U - BLACK
RichieRichZ06
St. Jude Donor '08
Thanks!!
There is no way for you to do it. The site is for GM employees only. Sorry.
Old Oct 25, 2006 | 11:25 AM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Thank you very much, i owe you a Zaino job!
Chas
To Column Lock Information Please
Old Oct 25, 2006 | 05:16 PM
C5Jimmy's Avatar
C5Jimmy
Whether you have the recalls done or not, still get the CLB no matter what!
Its not if it will happen, its WHEN it will happen!
Old Oct 25, 2006 | 06:05 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Old Oct 25, 2006 | 10:02 PM
LoneStarFRC's Avatar
LoneStarFRC
True story!
