[Z06] Need some help and tips
Old Sep 18, 2001 | 07:48 PM
Azn01Penny's Avatar
Azn01Penny
Default Need some help and tips
Hi everyone, I finally mastered how to start the car without rocking the car. I have a question tho about switching gears.. I am getting a forceful rock back when I switch gears. Probably not switching right. Can someone help me and tell me what might be the problem. If I can eliminate this rocking when I shift, I'll be a pro in manual tranny. :D
:cheers:
Bernard Sze
Old Sep 18, 2001 | 09:29 PM
gs568's Avatar
gs568
Default Re: Need some help and tips (Azn01Penny)
Bernard,
Contact me offline, I live in the Bay Area too. Maybe I can help you out.
Regards.
gs568
David
Old Sep 22, 2001 | 03:37 AM
whip383's Avatar
whip383
your probably letting off the gas before u depress the clutch or the happy medium in between?
Chan :cheers:
Old Sep 22, 2001 | 10:39 PM
Mover's Avatar
Mover
Default Re: Need some help and tips (whip383)
Chan :cheers:
That's probably it, but the alternative is your running it up fairly high in a given gear, then letting the clutch up quickly with no( or not smooth throttle). Don't do that It's really just a matter of practice. Shifting at lower speeds with gentle throttle pressure should give you smooth shifts. Then expand from there.
The throttle release should be at the same time as you press the clutch, not before, and not too much after, either, as you won't impress the girls that way :lol:
To Need some help and tips
