Tire Rub?
Old Oct 29, 2006 | 12:13 PM
Twin Screws's Avatar
Twin Screws
Default Tire Rub?
Trying to install 305/30YR-19 Michelin Pilot Sport PS2 or 19x11 SSRs in th rear of 2001 Z06...and they don't fit (rubbing duct and top of wheel well). Are spacers a bad idea?
Bought the rims from Tirerack...they claimed the offset of the rim would be fine.
Old Oct 29, 2006 | 12:21 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Offset for a 19x11 should be around 63mm.
I have had no problems with 305 rubbing, on a coupe...
Good Luck
Peace
Chip
__________________
..................Click for
Old Oct 29, 2006 | 12:24 PM
nmp27's Avatar
nmp27
Those rubbed with the car jacked up, but didnt when it was down on the ground, BUT in a bonehead move I had to clearance one of them by making a circle cut in the duct where it was rubbing, it's about 1.75 in diamater. I hope your offset is correct.
Old Oct 29, 2006 | 03:43 PM
Twin Screws
Default Wheels
So if I jammed them in and dropped the jack, they may not rub?
To Tire Rub?
