Question about take off
Old Oct 30, 2006 | 02:11 AM
SeaBass2001's Avatar
SeaBass2001
Default Question about take off
when at the track what should i hold my rpm's to at take off?
By the way i have an A4 with 2:73's and a corsa system
I would also like to know if anyone here who doeant have to many mods (maybe just like a catback and intake) has ran there car at an 1/8 of a mile?? if so what did you run?
Thanks for any and all input,
SeaBass
Old Oct 30, 2006 | 03:54 PM
SeaBass2001
Anyone????
Old Oct 30, 2006 | 04:05 PM
Dans97's Avatar
Dans97
Flaps : 10 degrees
Traffic: Clear
Engine Instrument's : In the Green
Vr : 55
J/k. . . Sorry I have no clue
Old Oct 30, 2006 | 05:53 PM
EHS's Avatar
EHS
For both of you, read this post, very, very carefully, and memorize it.
The gentleman is one of the best C5 drag racers out there:
http://forums.corvetteforum.com/showthread.php?t=759802
Old Oct 30, 2006 | 06:15 PM
Vega$Vette's Avatar
Vega$Vette
So HOW does this post help a guy with an A4?
Old Oct 30, 2006 | 06:35 PM
EHS's Avatar
EHS
Here, from that thread:
_______________________
"If you are running stock tires, keep your launch below 2500 RPM regardless of transmission type. If you are running a drag radial, make sure you sufficiently heat them with a burnout before staging. Either way make sure your stage shallow.
The following is a description of staging shallow: The are 2 yellow lights which indicate the staging area. They are separated by 7 inches. When the track worker waves you up you approach the lights and as your car rolls you will turn on the top light first (pre-stage). As soon as the first light goes on, stop. Then slowly nudge your car forward until the second light goes on (staged). Stop immediately! When you launch your car, the clock does not start until you break the beam of both the pre-stage and stage lights (the starting line).
As soon as both lanes are staged (The staged light in each lane is lit), the first of three large yellow lights will light. On the third yellow light begin your launch. With a shallow stage. your car will have a few inches to begin rolling before the stage lights are triggered indicating you official start....
First an optimum launch rpm must be established which is a function of ambient temperature, sun load, track surface, tire temperature, vehicle loading .... An optimum launch will allow enough wheel spin so that when the tires "hook up" to the pavement there is not a loss in vehicle acceleration."...
Here is what I do. No claim it's the best way.
Competition mode. AC and audio system off. Windows up. Tire pressure 44-48 psi (front); 24-28 psi (rear)....
What you are after is developing the launch "touch" combining input from all yours senses. I can feel the tires spin in the steering wheel and seat of the pant. Sight and sound help too. But the F1SC tires don't make much of a squeal when they spin.
I use Competition mode rather than "AH/TC off" because I want AH to intervene should the rear get substantially out of line. Just some insurance to limits "the worst that can happen."
Two last things you probably already know. Be sure your oil is above 155 degrees (preferably above 170) before you do launch practice. Also choose your spot wisely.
Why I ALWAYS Run in "Competitive Driving" Mode
I posted this in Feb 2002
I've alway run in COMPETITIVE DRIVING mode at the drags. Do it on principle...It has no effect whatsoever on my times unless my rear end gets seriously out of line, at which point active handling will be invoked, thereby saving my a $ $. In such a moment, my ET would be the last thing on my mind.
Today I narrowly averted a disaster that was not of my making. AH saved my butt and vindicated my practice of running with it turned on.
I made eight passes at Capitol Raceway in Crofton Maryland. On the fourth pass, I was next in line behind a highly modified car that spewed tranny fluid on the track just after the 60_ mark. Unfortunately, no one, including me, noticed the spill as it occurred. AND, I was next.... I had my best launch of the day (1.82) and hit 2d gear hard amidst his tranny fluid...whereupon my rear end moved violently right...toward the wall. Fortunately, Active Handling engaged and queued me to back out of the throttle immediately upon recognizing my predicament...but not before I had come within just a foot or so of the wall.
Had I turned AH off (as many people do), I surely would have hit the wall HARD. Wouldn_t have been my fault; but certainly would have spoiled the day. When that occurred, the last thing on my mind was my ET...which was a 12.81...in a day of 12.04 and a bunch of 12.1Xs, plus one trap of 118.1...all in COMPETITVE DRIVING mode.
Another post about my "wall incident":
The "queue" from AH means that within fractions of a second (literally) (1) my rear end moved violently right toward the wall and (2) AH immediately invoked counterveiling action. Both produced sensory inputs that deviated from the norm and I backed out of the throttle. The car came straight again nearly against the wall. It had moved right about 12 feet. Total time of the event was around half a second.
I also made some steering correction, but AH played two roles (1) its pulsing actions queued my senses and (2) it took psoitive counterveiling action to correct the out-of-line condition. Given that AH makes corrective adjustments many times in a tenth of a second, it certainly was the dominant factor in my staying off the wall. True, I backed off the throttle, but not until the accumulating sensory inputs caused me to recognize my predicament; but in those crucial tenths of a second AH had already been in action.
Lota folks can recover from just "loose." But few (without AH ON) can recover successfully from "violently loose." You may be one who can, I'm not.
Burn-out of BFG Drag-radials without a line-lock
Here is what I'm doing; no claim it's the best way.
Back into the waterbox if possible and immediately spin the tires just enough to get a full rotation of them, but NOT enough to throw (much) water up into the wheel wells.
Roll forward out of the water few feet; but do NOT roll so far as to put the rear wheels onto the rubber/VHT prepped area.
Make sure you're in COMPETITIVE DRIVING mode.
Launch on BFG Drag Radials...."
And, by the way, the second gentleman, Dans97, has a MN6, so the thread should help him as well.
Old Oct 30, 2006 | 07:02 PM
c5vette_dallas's Avatar
c5vette_dallas
hammer that b****... its got 2.73's
Old Oct 30, 2006 | 07:04 PM
Vega$Vette's Avatar
Vega$Vette
OK, Big long post but NO info on launch technique (RPM) with an Automatic.
Old Oct 30, 2006 | 07:06 PM
Vega$Vette's Avatar
Vega$Vette
Competitive Mode On - 3rd Gear - Point it Straight - Push the Gas Pedal to the Floor.
Old Oct 30, 2006 | 09:28 PM
EHS's Avatar
EHS
Really? Sorry I put it right at the top, before the post got too long.
Here you go.
Hope this helps.
Old Oct 30, 2006 | 10:27 PM
Vega$Vette's Avatar
Vega$Vette
Here you go.
Hope this helps.
FYI He's talking M6 or M12 NOT Auto.
Old Oct 31, 2006 | 09:51 AM
EHS's Avatar
EHS
I know, John, let me type this slowly, so that it's more clear.
I responded to both gentlemen in this thread (posts 1 and 2). That's why I started my post with "For both of you..."
Dans97 has a manual transmission car, in other words, something called an MN6. That makes Ranger's post completely relevant in all respects (well, except maybe the Active Handling part -- Option JL4 in that year (AH was optional in that year, you know), and I don't know if his car has it.
The other gentleman (SeaBass2001) has an A4 (that's an automatic transmission), but many of the items in Ranger's post remain applicable to him as well (like how to launch the car, tire pressures, TC/AH, etc.
You see?
Old Oct 31, 2006 | 11:36 AM
Vega$Vette's Avatar
Vega$Vette
I...mm t..y..pin.g slow j..us.t for ..you.
99% of rangers post has nothing to offer with regard to lauching a Stock A4 with 2:73s
This is all you need to know.
Old Oct 31, 2006 | 01:30 PM
EHS's Avatar
EHS
Could you also give me some help on tire pressure maybe?
30 psi cold all around sound OK?
Old Oct 31, 2006 | 04:37 PM
Vega$Vette's Avatar
Vega$Vette
If you are getting a lot of tire spin on launch I'd lower the rears to 24-26 lbs. (you're probably not getting much tire spin - 2:73s) By lowering the rear pressure you will offset any traction gains with increased drag so if your'e not spinning don't lower the pressure.
You can also run the fronts at a higher pressure if you want maybe up to 40 lbs (less drag with higher pressure).
The best thing to do is hit it they way it sits out of the box and then make slight adjustments to improve your times.
Have Fun
Old Oct 31, 2006 | 05:53 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
SeaBass
I had the same set up, (a4, 2.73) but only have traction cont. which kills my time. With the run-flats, it's hard to get a great launch. Seems that they get pretty slick if you burn out a little too much. The better launches I've got have been only torqued up at about 1400 rpm. It holds down some of the spin. I don't recall my 1/8 but the 1/4 was 13.3 @107. Not the greatest, I know.
oh, forgot.. it's more of a 'dance' with the "floor it" thing. Don't pound it down. Just get it there at a reasonably fast pace.
To Question about take off
