Spare tire?
Old Oct 31, 2006 | 10:06 AM
fright88's Avatar
fright88
Default Spare tire?
Ok so the other day I saw that someone had posted that they put a GTO spare in their car for a spare tire. I am thinking about getting some non run flats prety soon here and was wondering if anyone knew if there was any to fit a spare in our trunk without having it take all the space. Will the GTO spare work? Please let me know.
Old Oct 31, 2006 | 10:13 AM
timemender's Avatar
timemender
You could mount the spare to the outside of the bumper like they do on some vans. Otherwise – trunk so cavity big – tire so big – what else is there? You could invent and patent a shrink-ray machine I suppose.
P.S. Will the GTO rim fit on the Car? Keep in mind that tires of the same diameter must be used on a posi-traction axle.
Old Oct 31, 2006 | 10:51 AM
fright88's Avatar
fright88
Har har har funny stuff there. Seriously tho I don't know if it will fit. I don't remember what topic I saw that in and did a search and couldn't find it so I figgured I would post. I need trunk space for my wheelchair so I was curious what they were doing. I only live a few miles from work and have other vehicles and I have AAA and factory road side assistance so I am not too worried. Just a little curious.
Old Oct 31, 2006 | 11:57 AM
hotwheels57's Avatar
hotwheels57
The GTO spare tire/wheel will fit a C5 if the ID of the center hole is opened up slightly. As I recall, the OD of the tire is very close to that of the C5. You might research the question on the LS1/GTO site.
I've considered the same option, but the spare will take up a lot of limited trunk space and add weight. You might be better off considering buying a small 12v compressor, tire sealant (sensor safe), tire plugs/tools, etc.
Old Oct 31, 2006 | 12:51 PM
fright88's Avatar
fright88
that sounds like the way to go thanks for the reply
Old Oct 31, 2006 | 03:10 PM
GRAY BEARD's Avatar
GRAY BEARD
You joshin' right? I mean really?
Old Oct 31, 2006 | 03:13 PM
bonnell's Avatar
bonnell
I bought a ContiComfortKit from TireRack for $79 at the suggestion of other forum members...
http://www.tirerack.com/accessories/...tkit/index.jsp
Old Oct 31, 2006 | 03:16 PM
sailohio's Avatar
sailohio
To Spare tire?
