I have a C5 2000 coupe, with the stock wheels (17s in front 18s in rear). What do I have to change to install a set of c6 wheels as follows? P245/40ZR18 for the fronts and P285/35ZR19 for the rears.
JUST THE TPS .....SOME PEOPLE SAY TO PUT SPACERS ON THE BACK.....I DIDNT AND ITS FINE FOR ME.....I PUT C6 18--19 ON IT.....HEARS A FEW PIX....IF U HAVE N E ? HIT ME UP..../
FYI...I don't know if the pics are aftermarket c6 style wheels with the c5 offset, but the factory c6 wheels are a pretty tight fit (on the rear) with little or no clearance from the inner fender. I put my c6 wheels on a few months ago. I did install 1" adapters to the rear spindles to give me a "comfortable" clearance. The front wheels fit with no problems. The adapters moved the wheel out to be nearly flush with the fender....giving it a nice look..
those wheels came off a factory 07 c6 vette.....oem....so there not made for a c5 .....and what do u need clearance for?......my car is dropped all the way on the back on stock hardware with 2/3 the bushing cut....no problems yet
Nice look omarcoolguy. Have you pulled them yet to see if there is any rubbing? thanks
Crvtble do you have a pic of the 1" spacer and from where did it come? I have not made the decision yet but want the options of what i have to do.
funny u asked u just got back from the tire shop putting my old tps's in....and i noticed a few rub marks......so i put some 1/2 spacers hopefully it helps
I have a 2000 verte and just changed out my magnesium wheels for a set of chrome C6 wheels. I got them from AFS Wheels out of S. California. They are the same size as the stock wheels (ie 17 X 8.5--front, and 18 X 9.5--rear) with the factory offsets. The price was $745.00 with free shipping. My local Chevrolet dealer installed them with the pressure sensors for $75.00. They look terrific. Best thing I ever did to my verte.
I have 2003 coupe that I put stock C-6 wheels with BF-Goodrich tires.(Front) 245/40ZR 18 (Rear) 285/35ZR 19. I then put a ¼ inch spacer to correct the offset on the front and a ¾ inch adapter to correct the rear. I think that they look really great now, they set real close to the out side of the finder wells now. but with out the adapters on the rear they were real close to the inside of the finder wells. I thought that they might rub on the inside when cornering at higher speeds.
