Gremlins again!
Old Nov 1, 2006 | 02:05 PM
photoguy's Avatar
photoguy
Default Gremlins again!
OK. I pulled the car in the garage last night with 1/4 tank of gas.
Started it up the AM and the tank was empty and check fuel gauge came on immediately!
Whats up with this???
Old Nov 1, 2006 | 02:18 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
lots of these care have a fdaulty gas gague, it may have been reading falsely low, better than showing more than you have in the tank, i try to keeo mine more than half full, and my gague does all kinds of crazy stuff
Old Nov 1, 2006 | 02:29 PM
Could be your fuel sending units are messed up - Could only be sulfur deposits on them. Try running a bottle or two of Techron through the gas tank and see if that cures the problem. You also might want to switch brands of gas for a while and see if that helps.
Old Nov 1, 2006 | 03:20 PM
torchredfrc's Avatar
torchredfrc
I have this problem every once in a while. Techron & switching fueling stations seems to help. As a precaution, I use Trip A as a fuel odometer and Trip B as a oil odometer. I also don't let the car get below 1/4 of a tank.
Old Nov 1, 2006 | 05:33 PM
b98's Avatar
b98
I guess you want the extra key back now. I told her you would notice.
Old Nov 1, 2006 | 05:53 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Had the same problem with my 02. Had the right one fixed just yesterday and guess what? The left one took a dump a few hours later. Dealer says bring it in tomorrow. Good thing its a warrant item.
To Gremlins again!
