wheel hop.....
Old Nov 3, 2006 | 10:36 AM
02gt350's Avatar
02gt350
Default wheel hop.....
whats the best mods to get rid of this???
Old Nov 3, 2006 | 12:08 PM
Dave1998's Avatar
Dave1998
Ford 9" straight axle rear end !
Old Nov 3, 2006 | 12:11 PM
02gt350's Avatar
02gt350
dont tempt me. Ford still runs deep in my blood
WKMCD's Avatar
WKMCD
Lot's more RWHP...Spin is always better than hop.
Old Nov 3, 2006 | 12:13 PM
02gt350's Avatar
02gt350
hop is because of spin
Old Nov 3, 2006 | 01:29 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
DTE has a great write up on what helps reduce wheel hop. Make sure you're running a DTE brace, otherwise youre likely to break your differential and transmission while suffering wheel hop.
From what i understand different shocks, sway bars and poly bushings were about the only options you have. Change to a different tire, either a hair softer or a bit harder, depending on your goals.
Old Nov 3, 2006 | 01:39 PM
Stangkiller
If you obliterate the tires you're much less likely to get wheel hop...which is why i do burn outs in 2nd gear instead of first.
First and 2nd gear no longer have any wheel hop issues, only 3rd and part of 4th
Old Nov 3, 2006 | 02:08 PM
02gt350's Avatar
02gt350
To wheel hop.....
