I need help!!!
Old Nov 3, 2006 | 11:07 PM
Luv My Vette's Avatar
Luv My Vette
Default I need help!!!
Putting my vette to bed this weekend for the winter and am not sure what to do exactly as things have been a little inconsistent on the forum. I have 25k miles on her and my oil is at 56%. I have the original battery which I am going to take out and check if there is any damage. I will replace with Gel type in spring. Wondering about transmission service and anything else that might be pertinent. I am thinking about buying a car cover as well and am intrigued about that bag type storage unit.... Do you have to suck the air out of that bag or is it better to keep the air in there....... A little confused....... Any help here would be greatly appreciated
Old Nov 4, 2006 | 12:32 AM
wallemon's Avatar
wallemon
At a minimum: wash, wax, change oil (don't forget to reset the oil usage monitor and be sure to use 100% synthetic oil) and filter, park in a garage and protect with a car cover. And WELCOME to the fraternity of Corvette ownership. I fulfilled a lifelong dream when I bought my first Corvette....and before you knew it I had 5 of them!!! Life is GREAT!
Old Nov 4, 2006 | 12:37 AM
Luv My Vette
100% synthetic = Mobil 1 ... Is there a better alternative???
Old Nov 4, 2006 | 10:22 AM
rws.1's Avatar
rws.1
- Wash, wax, complete detail
- change engine oil and filter
- other fluids are fine at 25K miles
- ensure antifreeze and wash fluid will protect below temp you expect over winter
- pump up tires to max on side wall
- humidity in concrete can rust the frame rails over the long term
so I cover concrete floor with a heavy blue poly tarp and park on the tarp.
- I prefer to leave the battery in and on a battery float charger
- I put some dessicant in the passenger compartment and close the windows to minimize the possibility of mould growth
- some silicone grease on the weatherstripping is a good idea.
- put fuelstabilizer (STABIL) in gas tank and fill the tank
Old Nov 4, 2006 | 11:10 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
This link will point you to the most comprehensive article I've ever read on the topic.....click here!
Old Nov 4, 2006 | 11:15 AM
Blue Lion's Avatar
Blue Lion
Mobil 1 is synthetic and what most of us use.
Depending on how old your car is you may want to change more fluids even though you only have 25k on the clock. My car is an early 2000 model with 39k on it. I went ahead and changed all the fluids recently as they were 7 years old in some cases.
Old Nov 4, 2006 | 11:17 AM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
The only thing I do different is I just disconnect the battery.
Old Nov 4, 2006 | 11:27 AM
NJ Vette Guy's Avatar
NJ Vette Guy
With all the stuff we should do, to store the car for the winter.....
I think it will be just easier to move to St. Thomas, USVI..... This way I can drive the car year-round.....
Old Nov 4, 2006 | 01:26 PM
Luv My Vette
Old Nov 4, 2006 | 11:12 PM
wallemon's Avatar
wallemon
Mobile 1 is put in by the factory and was one of the first 100% synthetic oils. It is also what I use in a couple of my vettes but it is far from the only 100% synthetic out there. I recently saw a comparison in one of the corvette mags I subscribe to that tested Royal Purple vs. Mobil 1 on a dyno. That was the only change to the vehicle and as many of the other variables (engine temp, etc) as possible were kept the same. Bottom line, the same car with the same engine with the same environmental conditions yielded an increase of 5 horsepower at the rear wheels using royal purple. It got me thinking of switching (which I haven't done yet but I just read the article this fall) because if 5 hp can be yielded just by changing the oil then there must be significantly less friction between the moving parts with royal purple than with Mobil 1. I can't imagine that Mobil will just sit back and not respond to this challenge but who knows?
To I need help!!!
