shifter rattles
Old Nov 4, 2006 | 06:42 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default shifter rattles
anyone with hurst short-throw shifter(s) have rattles? or other problems? looking for a replacement for the stock unit... thanks in advance
Old Nov 4, 2006 | 06:58 PM
jbauch357's Avatar
jbauch357
Rattles are a common problem for any aftermarket short-throw shfter, and the noise typically comes from the stock shift **** so it's a pretty easy fix. Depending on what you are looking for there is a vast range of choices for shifters, but far as I can tell the MT 6-shooter is the most widely accepted (I am biast cause I own one too).
Old Nov 4, 2006 | 06:59 PM
BlackZ06's Avatar
BlackZ06
I have had the Hurst for several years and have had zero problems with it. No rattles ... just works great.
Old Nov 4, 2006 | 09:06 PM
TEXHAWK0's Avatar
TEXHAWK0
Cut boot to fit tight around the base, and installed Hurst ball on top. No extra noise or rattles.
To shifter rattles
