Plate question....
Old Nov 5, 2006 | 02:54 PM
tom3257's Avatar
tom3257
Default Plate question....
Hey folks, Is there a way to find out if someone in my state already has the vanity plate I want. I hate to fill out the application and write a check...etc.... If I could find out first...tom3257
Old Nov 5, 2006 | 03:01 PM
pops98's Avatar
pops98
In Virginia you can go to the DMV website and try several combinations. If that plate is in use, it will tell you so. Maybe your state has a site that does the same. Good Luck
Old Nov 5, 2006 | 04:16 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Hey Tom put in a profile, it lets people know where you are. You can get better answers to questions then.
New york has a website that tells you if a plate is available. Best bet most states do also.
Old Nov 5, 2006 | 04:19 PM
msj2222's Avatar
msj2222
I'm in Ma. and I just called the registry and asked...they were actually helpful !
Old Nov 5, 2006 | 05:44 PM
R Devil's Avatar
R Devil
Same in IOWA.
Old Nov 5, 2006 | 05:51 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
same in texas
Old Nov 5, 2006 | 05:59 PM
rws.1's Avatar
rws.1
Michigan let's you check on line for availability...
Through the Secretary of State web site
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
NYSDMV.com lets you "build it" online. If it's available it even shows you what it will look like on the plate.
Old Nov 5, 2006 | 07:01 PM
JWG's Avatar
JWG
St. Jude Donor '07
Florida has this
https://www6.hsmv.state.fl.us/mvchec...check/main.jsp
Old Nov 5, 2006 | 08:10 PM
At least in Missouri, you can call the DMV section that deals with personalized plates and they will tell you if a plate has been taken. Sure saves a lot of frustration.
Old Nov 5, 2006 | 08:38 PM
Doo's Avatar
Doo
St. Jude Donor '03 & '06
I didn't see anything for your state.
http://state.tn.us/revenue/vehicle/l.../specialty.htm
Illinois doesn't have any way of checking either so I sent them a list of 15 different plate requests stapled to my application and they ran them all. I was able to get # 12 on the list.
Good Luck
Old Nov 5, 2006 | 08:49 PM
mutts2's Avatar
mutts2
Default Go to County Clerk Ofc
I live in Cumberland County and the C.C. did a look up on the spot...
To Plate question....
