Crazy garage idea?
Old Nov 6, 2006 | 08:21 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Default Crazy garage idea?
This may seem nuts, but I can't really figure out what's wrong with it. So here's your chance. Shoot this one down.
We talk about garage flooring all the time; paint, tiles, racerdeck, etc. Well what about hardwood floors?
Sounds crazy right?
But think about it. If it gets crappy looking, just go down to Home Depot, rent a sander and a week later, new floors.
Car brings in water and water makes wood rot, riight? Well these new polyurathane paints and stains will stand up to almost anything. We've got 'em in our kitchen and they've been splattered with grease, water, you name it and it mopped right up.
So what's the problem here? Yeah, I know they'll get all scratched up, but so will everything else nice. But wood can be sanded, tile can't.
Shoot this one down. Love to hear why this isn't a good idea.
Old Nov 6, 2006 | 08:23 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
I am by no means a floor guy, and maybe totally wrong, but...
It is the water that gets under the floor that will cause the most amount of problems for you bud... You will likely wind up with some type of mold or rot issue...
Old Nov 6, 2006 | 08:28 PM
Ta-taaa's Avatar
Ta-taaa
If you use wood... Your not going to want to do any jacking or using jack stands.. or even ramps. Plus oil, gas and wood.. ummm make a pretty good combo for fire!!!
But if ya do it post some pics!!
Good Luck
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
You wouldn't, by chance, be a Bulldog fan now would ya?
Just kiddin ya Jack and no I don't really have any input of your flooring idea. Sounds good on the surface though.
Old Nov 6, 2006 | 08:30 PM
devnull's Avatar
devnull
Ouch dude.....
Ouch.
Old Nov 6, 2006 | 08:38 PM
allred's Avatar
allred
As stated.....wood does not like being exposed to the "elements"......and it would be a pretty expensive floor too!!!
I think I'll stick to my painted gray garage floor.
Old Nov 6, 2006 | 08:43 PM
5W0P3's Avatar
5W0P3
I like my floors just the way they are... however, they're getting epoxied in the spring
Old Nov 6, 2006 | 08:46 PM
JACKAL0PE's Avatar
JACKAL0PE
Jeeez! Not THIS year Gator, that's for sure. The Dawgs are so lousy this year I've even started watching the Falcons.
Old Nov 6, 2006 | 08:55 PM
yaknow's Avatar
yaknow
You may also want to consider how your going to put floor down, if you use hardwood you will need a subfloor over the concrete of a minium of 3/4" plywood glued to the concrete before laying hardwood down. The obvious water issues between the flooring would be problematic. Raising the floor 1" + and creating a transition at the point of entry my also be a concern.
Old Nov 6, 2006 | 09:04 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
For you that makes sense. My wife has been a Falcons Fanatic for well on 20 years now. I follow Tampa Bay (poor me) and we live in Jersey! Go figure. We live 5miles from Eagle land. And dislike them as much as Mustangs (the car I mean)
Old Nov 6, 2006 | 09:05 PM
JACKAL0PE's Avatar
JACKAL0PE
Good point, but I had considered that. I figured I'd bevel the edges.
That water issue may be a deal killer though.
Old Nov 6, 2006 | 09:26 PM
parussky's Avatar
parussky
Many years ago I worked in a steel mill in Pittsburg, CA and all of the floors were wood block over concrete. They used maple wood blocks about 4" x 6" x 4" high and they were set with the end grain up. We had huge tractors that we ran along with 30-50,000 lb coils of steel that we set on them. Only thing that would hold up was wood. When a block would crack or deteriorate it was easy to replace.
Doubt that you would want to do this in your garage, although I thought about hardwood from Lumber Liquadators for my new 4 car garage. But will probably use Rustoleum epoxy like in my last garage. Still looked new after 26 years.
Old Nov 6, 2006 | 09:30 PM
5W0P3's Avatar
5W0P3
I think i've read this before... you're not on garagejournal.com are you?
Old Nov 6, 2006 | 09:35 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Major indentation marks
Old Nov 6, 2006 | 09:54 PM
JACKAL0PE's Avatar
JACKAL0PE
That's what 3/4" plywood is for.
Old Nov 6, 2006 | 09:58 PM
5W0P3's Avatar
5W0P3
I think if this was a viable option... you'd see it being used.
Old Nov 6, 2006 | 10:01 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I'd carpet it. **** would absorb those pesky drips too.
To Crazy garage idea?
Old Nov 6, 2006 | 10:25 PM
yaknow's Avatar
yaknow
subfloor for nailing flooring down
Old Nov 6, 2006 | 11:16 PM
corvettedoug's Avatar
corvettedoug
I saw a product that looked pretty cool speed tv the other day. I believe I was watching Car Crazy and they had some tiles that looked a lot like hardwood floors when installed. The had the benefits of tiles (drainiage, cleanup and easy installation) but looked like wood flooring, well at least on TV.
Unfortunately I do not remember the manufacturer, but I am sure you could do a search and find it.
Old Nov 7, 2006 | 12:58 AM
3RD-INF's Avatar
3RD-INF
I retired from Armco Steel in Kansas City. We also had a lot of the floors in the different mills that were wooden. Damn strong floor. Looked like crap but they worked.
