ABS/Active Handling lights
Old Nov 7, 2006 | 08:22 AM
CBLeitch9's Avatar
CBLeitch9
Default ABS/Active Handling lights
When I started the car this morning, the DIC read service ABS/service active handling and then the ABS & Active handling lights came on in the gauge cluster. I proceeded to drive it for a little while, turned it off, started it up again, drove it the rest of the way to work(appx. 20 miles) and then it never came on again. Any idea as to what is going on? Is this the beginning signs of something about to go bad? Opinions wanted...thanks!
Old Nov 7, 2006 | 08:24 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Check for codes.
Old Nov 7, 2006 | 08:35 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Check for codes. It could be faulty grounding or a problem with your ECBM. Here is a link to a thread listing a ton of members who have had issues with this module. Also do a search and I'm sure you'll find a ton of other info.
http://forums.corvetteforum.com/show...ctive+handling
To ABS/Active Handling lights
