air conditioner issues (2000 cp)
Old Nov 7, 2006 | 08:51 PM
VTFNATC's Avatar
VTFNATC
Cruise-In IV Veteran
Cruise-In V Veteran
Default air conditioner issues (2000 cp)
The air conditioner will not come on. it looks like it tries to, the light comes on for a minute, then it goes back off. i never hear the load on the engine increase any so i don't think it's ever kicking the compressor on. the ambient air temp sensor had to be replaced, and i had to put a new battery in it today too. neither fixed the issue.
any ideas?
Old Nov 7, 2006 | 10:49 PM
INaband's Avatar
INaband
CI 7-8 Veteran
If the low pressure cut out switch is kicking in, that means you may be low on R-134a. I would vac it down to check that for one thing..
Old Nov 7, 2006 | 11:10 PM
omarcoolguy's Avatar
omarcoolguy
check the fuse.....and cheack it for the fans also.....cuz if ur cooling fans arent turning on.....the ac wont
To air conditioner issues (2000 cp)
