Thompson astro tops $uck !
Well the tops looked great ! then a couple of days later it rained
and both cars leaked bad around the front window corners right into the seat
both sides !my tops had never leaked before , so I called customer service , if you can call it that , and I ended up with Drew
, a very customer oriented technician
, that right of the bat proceded to tell me that basically unless I figure out a way of throwing a tarp on my vettes to ship the defective tops back , there was nothing he could do .I did explain to him that his tops are cut wrong at the front corners , a quarter inch too short and that I could see how the water was entering the car , but he tells me that my eyes are lying and his product is just fine
So it appears this one is going to the lawyer in the next couple of days
So next time you think of even giving Astro a call for your new top , think that you may have to deal with Drew just like i did !
don't say you were not warned !
If the back hook has too much tension, that can cause the issue. The hook can be adjusted to correct. Additionally, the front fastening levers are attached to the top with allen screws. Be adjusting those you can tweak further.
I suspect you can solve your problem. It took me approx 15 minutes to complete the repair. Good luck.
She told me I should have looked deeper in the shipping box, laughed, and walked away shaking her head.
Once I got it adjusted, it fit great!
I did talk to someone over at a different shop like this and he specifically mentioned the adjustment that would be needed.
Corvette Targa Top Adjustment
Roof Lift Off Panel Adjustment
1. Perform one or more of the following five adjustment procedures to properly align the roof lift off panel.
2. To adjust the front striker for up down roof alignment perform the following steps:
3. Remove the windshield upper garnish molding. Refer to Windshield Upper Garnish Molding Replacement in Interior Trim.
A. For major up down roof adjustment loosen the striker bolts and reposition the latch striker up or down.
B. For minor up or down roof adjustment loosen the striker outboard bolt and slightly loosen the inboard bolt, pivot the striker on the inboard bolt in 2 mm (0.08 in) increments up or down.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
C. Tighten the striker bolts. Tighten
Tighten the roof front latch handle striker bolts to 10 N•m (89 lb in).
D. When the striker is properly adjusted the handle will snap closed.
4. Install the windshield upper garnish molding. Refer to Windshield Upper Garnish Molding Replacement in Interior Trim.
5. To adjust the front latch handle forward or rearward perform the following steps:
. Loosen the latch handle bolts.
A. Position the latch handle forward or rearward. Maintain a minimum of 2 mm (0.08 in) clearance between latch handle and the latch striker to avoid squeaks and rattles.
B. Assure the latch handle base is parallel to the striker to provide clearance to the sunshade mirror door.
C. Tighten the latch handle bolts. Tighten
Tighten the roof front latch handle bolts to 13 N•m (10 lb ft).
6. For major rear latch adjustment adjust the rear latch striker performing the following steps:
A. Remove the roof lift off panel.
B. Remove the roof bow center interior trim panel. Refer to Trim Panel Replacement - Rear Roof Bow in Interior Trim.
C. Loosen the rear latch striker attaching bolts.
D. Adjust the position of the latch striker forward or rearward for major adjustment.
E. Tighten the striker attaching bolts. Tighten
Tighten the roof rear striker bolts to 10 N•m (89 lb in).
F. Install the roof lift off panel.
7. For minor rear latch adjustment, adjust the latch handle hook one turn at a time to achieve moderate pressure to the latch as follows.
A. Loosen the set screw locking the latch hook.
B. Turn the hook in to tighten or out to loosen.
C. Tighten the set screw.
D. Install the roof panel.
8. To adjust the rear locator perform the following steps:
. With the roof installed on the vehicle loosen the locator mounting bolts.
A. Reposition the locator.
B. Tighten the mounting bolts. Tighten
Tighten the roof rear locator to locator bracket bolts to 10 N•m (89 lb in).
