[Z06] Back to track tonight
Old Nov 8, 2006 | 08:16 PM
Zosixin's Avatar
Zosixin
Default Back to track tonight
Going to the drag strip tonight, hoping to better my 12.9 last time out. The weather should be about 65f. Should I drop the air in my rear tires? They are at 30 as are the fronts. Thanks
Old Nov 8, 2006 | 08:22 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
24 Back, 40 front
Old Nov 8, 2006 | 08:32 PM
Zosixin's Avatar
Zosixin
Thanks I will try it.
Old Nov 9, 2006 | 09:46 PM
Zosixin's Avatar
Zosixin
Yesterday I went to the Las vegas drag strip. My best of 5 runs was 13.04 at 107.9. Two runs were very similar, 1306 and 13.9 both at 107mph. My 60ft times were all about 1.98. The two other runs were 13.2. I have 20 runs with my 03 z. It has a blackwing. I had gotten a 12.91 last time out, with a 1.91 60ft. There was another 03z with cai and drag radials running 12.3's. I know I can improve some. Any thoughts? Thanks Brian
Old Nov 9, 2006 | 10:22 PM
Chalky's Avatar
Chalky
60 ' times are quite good. Normally difficult for most to get 60' under 2 seconds.
Would be curious to know more about temp and elevation and trap speed of your car and other Z06.
Where RPM are you shifting?
Powershifting 1st-2nd?
Old Nov 9, 2006 | 10:54 PM
Chalky's Avatar
Chalky
Figures Density Altitude and corrects ET and Trap Speed for sea level
Temp(*F):
Humidity(%):
Track Alt.(ft.):
Pressure(in.):
ET:
Trap Speed(mph):
Based on:
Temp: 78°
Humidity: 17%
Track Altitude: -280 feet
Pressure: 29.6 in.
Density Altitude = 1317 feet ET MPH
Uncorrected 13.04 @ 107.9
Corrected 12.85 @ 109.43
Found your et and MPH. MPH is down. I would expect the car to MPH better. I guessed at the above info for LV area last night. I would think car should be closer to 12.5 and maybe 112 mph.
MPH is typically a matter of HP and ET is usually a matter of driver skill/technique.
JMHO. Hope it helps.
Old Nov 9, 2006 | 11:46 PM
bigfrank's Avatar
bigfrank
Originally Posted by Chalky
Saw your name in this post. Is this your friend's car?
http://forums.corvetteforum.com/show....php?t=1542531
http://forums.corvetteforum.com/show....php?t=1157557
http://forums.corvetteforum.com/show....php?t=1130748
Old Nov 9, 2006 | 11:48 PM
Chalky's Avatar
Chalky
From what I can figure out from the thread, the car is not my friends. Doesn't own a boat or a condo.
Old Nov 9, 2006 | 11:51 PM
ViperDave650's Avatar
ViperDave650
it seems as though it's changed hands a few times but either way it's a very nice price for the new owner.
Old Nov 9, 2006 | 11:54 PM
Chalky's Avatar
Chalky
The wheels make me wonder. Joe "Gramps" did have the original wheel lips polished by Panther. It could be Gramps's car though. Gramps sold it to a dealer in SW IL. Lost track of it after that!!
Old Nov 10, 2006 | 12:01 AM
McGintyZ's Avatar
McGintyZ
One of the poster has a VIN# posted so the owner need to verify that
Originally Posted by Z-THREAT
...this car came from the Illinois area.
John
Old Nov 10, 2006 | 12:11 AM
Zosixin's Avatar
Zosixin
The Las Vegas track is at 3500 ft elevation. the temp was about 75f.
Old Nov 10, 2006 | 10:23 AM
Chalky's Avatar
Chalky
http://www.modulardepot.com/density.php
Try this site for corrected et/mph. I was using the wrong elevation. Using 3500 elevation, 75 temp, hum 17% and barometer of 29.6, it corrects to a strong 12.03. You really need to know temp, altitude, barometer, humidity at time of runs to use the calc link.
Temp(*F):
Humidity(%):
Track Alt.(ft.):
Pressure(in.):
ET:
Trap Speed(mph):
Based on:
Temp: 75°
Humidity: 17%
Track Altitude: 3500 feet
Pressure: 29.6 in.
Density Altitude = 5750 feet ET MPH
Corrected 12.03 @ 115.28
Hope this helps.
Old Nov 10, 2006 | 03:27 PM
Zosixin's Avatar
Zosixin
Thanks Chalky. I didn't know the elevation would make that much of a difference
Old Nov 10, 2006 | 03:36 PM
Chalky's Avatar
Chalky
Air temp, elevation and humidity all play a roll in car performance.
12.0's are difficult on stock tires but 114-115 MPH is doable at lower elevations.
Old Nov 10, 2006 | 03:53 PM
Zosixin's Avatar
Zosixin
I looked up the Las Vegas track, it is 2200 ft elevation. Thought it was higher. Using the formula it corrects to 12.44 at 112.
Old Nov 11, 2006 | 11:08 AM
GARY2004Z06's Avatar
GARY2004Z06
Still a good run. I use 50psi front and 26.5 psi rear. Launch and track prep are critical, especially to half track where traction may become limited on shifts. Keep practicing.
Good luck.
Old Nov 11, 2006 | 05:00 PM
Chalky's Avatar
Chalky
1.9 60' is always nice.
Old Nov 11, 2006 | 05:38 PM
Zosixin's Avatar
Zosixin
Thanks everyone. I am going to take off my motorsport wheels and put the stockers back the next time out. It will be interesting to see if they make a big deference. The ones I have are about 8lbs heavier. I think that is what is hurting my trap speeds.
To Back to track tonight
