antifreeze ?
Old Nov 8, 2006 | 08:45 PM
elctroman's Avatar
elctroman
Default antifreeze ?
i just bought my 2000 this year and i cant see any anitfreeze in the resivour ,what kind should i add to it ,thanks
Old Nov 8, 2006 | 08:49 PM
CMYC4GO's Avatar
CMYC4GO
It takes the pink stuff.
Old Nov 8, 2006 | 09:40 PM
Oldvetter's Avatar
Oldvetter
Yep, dexcool.
Old Nov 8, 2006 | 09:49 PM
rws.1's Avatar
rws.1
Look for a Brand that says DEXCOOL>
I use Prestone. The reservoir has a cold and a hot fill level, I you look closely you will see it.
Old Nov 8, 2006 | 10:03 PM
elctroman's Avatar
elctroman
but it's black you cant see the fluid
Old Nov 9, 2006 | 12:38 AM
Chris.Shea's Avatar
Chris.Shea
the bottom is clear
Old Nov 9, 2006 | 12:40 AM
Dexcool or equivalent is the type you need. May want to see if there is a leak somewhere too if in fact your reservoir is low on coolant.
Old Nov 9, 2006 | 02:48 AM
Bill Dearborn's Avatar
Bill Dearborn
If you do not know the history of the car you should assume it is overdue on the coolant change. GM says every 5 years or 150K miles.
Bill
Old Nov 9, 2006 | 10:01 AM
GrandSportRob's Avatar
GrandSportRob
It's a 7 year old car, get it flushed...I flushed my 99 when it was 5 years old even though it only had 25k miles..
To antifreeze ?
