[Z06] Shock Woes
Old Nov 10, 2006 | 10:00 AM
bill weatherall's Avatar
bill weatherall
2nd Gear
Default Shock Woes
I Have A Totally Modified Blown 02 Zo6 ,stroker,12lbs Boost The Best Of Everything However,i Came To Me With Some Drag Shox Fand R And Im Not Shure About The Overall Handling The Shox Are Qa1 50/50 12 Adj Are They Ok?
Old Nov 12, 2006 | 07:47 AM
3 Z06ZR1's Avatar
3 Z06ZR1
I would pull them and replace back to stock, but thats me.
Sounds like you have a adjustable shock for drags maybe.
Old Nov 12, 2006 | 11:47 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
The 50/50 are not the Drag shocks, as the Drag shocks have 90/10 valving on the fronts. Are you having problems with them? If so try different settings to get them dialed in to where you like them. I had them on my '96, on the street I ran a 4Front/3Rear. Autocross I mostly used a 6Front/5Rear. I found that anything over a 8 or 9 was just too stiff.
On the Drag Strip you will want to start low, usually a 1-2 Front setting.
Don't get frustrated, give the shocks some time before changing to another setting. I found them to be very versatile!
To Shock Woes
