Flush Mount tail lights?
Old Nov 11, 2006 | 05:48 PM
FRED HAMBLE's Avatar
FRED HAMBLE
Default Flush Mount tail lights?
I ordered a flush mount taillight kit. When I went to install it the lights bulged at the top and there still was a lip at the bottom? Did I do something wrong or is this the way they should be???? They do not look flush as they do not follow the angle of the rear cover?
Anyone else experience this. Would appreciate any pic showing their flush mounts.
FRED
Old Nov 11, 2006 | 05:51 PM
ctvette2003's Avatar
ctvette2003
I had the same issue, first did you remove the small ridge on the light? It has to be nipped off. I ended up shaving about another 1/8 to get mine they way i wanted te to.
Old Nov 11, 2006 | 06:06 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
The tops of mine are flush and there is a slight lip on the bottom FWIW.
Old Nov 11, 2006 | 06:11 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
You can always go to Lowes or HD and get some plastic shims and adjust it...
I did mine all with plastic shims and longer screws...
Peace
Chip
__________________
..................Click for
Old Nov 11, 2006 | 08:27 PM
poolhustler's Avatar
poolhustler
I bought the kit from WWC and added shims to mine to adjust them to look better!!
Russ...
Old Nov 11, 2006 | 08:36 PM
molten vett's Avatar
molten vett
mine look like that too. i dont really care for the look that much i might take them off.
Old Nov 11, 2006 | 08:55 PM
J Z06's Avatar
J Z06
you can use shims from lowes or home depot.
mrnuke ground mine at an angle so they'd sit level with the bumper housing. without the grind, they protruded on top and tucked in on the bottom.
a little tlc/fenagling and you'll acheive the perfect look.
Old Nov 11, 2006 | 10:13 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
I made my own kit via Lowes. Consisted of nylon spacers and some weather striping. They fit perfect.
Old Nov 11, 2006 | 10:33 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Could you provide some more details. I may be interested in this myself. I want to do it right.
TIA
Old Nov 11, 2006 | 11:47 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
I put my kit on and it fit perfectly without any modification at all.
Old Nov 12, 2006 | 04:45 AM
CMYC4GO's Avatar
CMYC4GO
If you do, and want to sell the kit, let me know. Thanks
Old Nov 12, 2006 | 08:07 PM
FRED HAMBLE
ttt
Old Nov 13, 2006 | 01:15 AM
jozGS4's Avatar
jozGS4
TIA
+1
Old Nov 13, 2006 | 09:11 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
I did my own buying the spacers and longer screws from Home Depot and I never took the time to get it to fit just right. Was never really happy with them so I took them off when I swapped in the Halo LEDs.
To Flush Mount tail lights?
