[Z06] halltech trap vs stinger
Old Nov 13, 2006 | 02:43 AM
svtsilverback's Avatar
svtsilverback
Default halltech trap vs stinger
pros and cons please. coming from Lightning forums where this is a huge debate. i have run both open filter and ramair kit on my L and could not tell a diff. any facts like dyno# or 1/4#s. any back to back testing on same track/dyno? which do you have and why? thanks brian
Old Nov 13, 2006 | 04:18 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Can't say about the trap but the Stinger is improved
by doing the "window mod".
Which is cutting your radiator
panel. So the bottom of the filter gets the cold air from
radiator pocket below.
Old Nov 13, 2006 | 12:05 PM
wamara's Avatar
wamara
Cruise-In II Veteran
In stock configuration, the TRAP should be bringing in cooler air than the Stinger. SUPPOSEDLY the shape of the TRAP improved the airflow path into the MAF, or some such claim . When Jim Hall first came out with the TRAP, it got a lot of positive comments. He posted some dyno #s and there were some 1/4 mile times showing some pretty impressive results. You may be able to do an archive search and look for those posts (2+ years ago?)
Old Nov 13, 2006 | 12:47 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi svtsilverback -
The main thinkg that I like about the stinger is the ability to get to the filter - although you really don't have to clean these filters frequently (probably 50k miles for most folks that don't live on a gravel road).
The airbridge on the trap I have causes a slight bulging of the hood in the center where it makes contact when the hood is closed - no big deal but an observation.
I have no hard strip numbers - but I was running ~372-374 rwhp with just the TRAP and a tune.
If I were buying one today, I would go for the stinger personally.
That said - I would just be modding my stock airbox if I had no intake or throttle body/maf mods - that would flow as much air as the maf could handle anyway.
best regards -
mqqn
Old Nov 13, 2006 | 10:55 PM
svtsilverback
thanks guys. like i said everyone has an idea on which intake system is better in the lightning forums. is the stinger worth the $$$ or is there a better one out there? callaway's honker seems to have good comments on here.
Old Nov 14, 2006 | 01:29 AM
geterdone's Avatar
geterdone
where do you get the trap?
Old Nov 14, 2006 | 10:14 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi svtsilverback -
If you have a stock MAF and TB - just mod your airbox lid and save the money -
No - the aftermarket air intake systems are not worth the $$$ if you are running a stock MAF and TB.
best regards -
mqqn
Old Nov 14, 2006 | 10:18 AM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Originally Posted by mqqn
Hi svtsilverback -
best regards -
mqqn
I respectfully disagree. check the the Z06 fast list for insight on what the CAI can do for power/times.
Robert
Old Nov 14, 2006 | 12:11 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Robert
Hi Robert -
One of our forum members showed that the MAF is the limiting factor in the flow of our intake systems.
http://forums.corvetteforum.com/show...ight=RedHotZO6
He put several systems on a flow bench, and the flow rate for a modded stock airbox lid was greater than the flow capabilities of a stock MAF.
Perhaps the colder air is a factor - but for the money - with a stock MAF and TB, I stand by my advice.
Also - looking at the fast list - most (if not all) of the cars listed as CAI are also running drag radials....Might have some impact on launch? I don't see a list of otherwise stock with just CAI as compared to otherwise stock and modded stock airbox.
To each his own - please note that I too spent the bucks on aftermarket CAI for both of my cars - but I would not have had I known what I know now.
best regards-
mqqn
Old Nov 14, 2006 | 12:13 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi geterdone -
I bought my TRAP from Jim Hall at Halltech.
best regards -
mqqn
Old Nov 14, 2006 | 02:21 PM
DaBeast's Avatar
DaBeast
isnt there 2 types of haltech CAI??
i have one that u dont have to cut throgh the radiator shroud
Old Nov 14, 2006 | 02:28 PM
Robert56@RNS
Collections Hold
Hi Robert -
best regards-
mqqn
Well there's more to it. We will never likely see the limit of the MAF on our cars. Also, the real deal is how easly we can get that air. Yea the stocker can flow x amount of air, but under what conditions, and an aftermarket CAI does this using less hp because it has less restrictions. Some think they have it all figured out, however, the fast list is all you need when deciding whether or not a CAI works. Even Chevy realized the restriction in the stock air box, and had reached the limit of HP at 385 in '01. They added an opening in '02 to the air box to get the 405hp among other things. Now that same air box does it's job, but some want more hp and thus the easiest add on, a CAI that breathes free'r than a stock box.
Robert
Old Nov 14, 2006 | 03:35 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Robert
Hi Robert -
Well - if the stock MAF limit cannot be reached, then that says it all.
The question was not does a CAI breath freer than a stock airbox, it was are they worth the $$$?
I added, for the original poster, my opinion, that since a MODDED stock airbox flows (for all intents and purposes) as well as the aftermarket CAI's (reference my link above...), I opined that the CAI money is better spent elswhere (headers or such for instance).
So - if a modded stock airbox can outflow the maf, and by your own admission the MAF limit might never be reached, I rest my case your honor.
Again - the fast list does not show any proof that CAI is the bomb - it does show that drag radials will lower your et's significantly (along with mad driving skills).
For my purposes, and I do not sell any performance parts, I am a consumer, the stock modded box will do 'ya until you open up the intake tract on the engine side.
So I guess I do have it figured out.
BTW - love your harley - looks like a chop you could actually RIDE - nice job.
best regards -
mqqn
Old Nov 14, 2006 | 03:39 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi DaBeast -
The TRAP sustem has two "airbridge" pieces, one that replaces the stock airbridge and another that runs from the maf up under the front frame rail and puts the filter right behind the license plate. In a Z06, it is (in theory) getting much cooler air from the screens in the front fascia.
The Stinger eliminates the second tube and puts the air filter in the stock airbox location.
best regards -
mqqn
Old Nov 14, 2006 | 05:15 PM
Robert56@RNS
Collections Hold
Hi Robert -
best regards -
mqqn
Cool, though I will stick with my Vararam.
Yea it's a rider, but a little hard on the back being a hard tail.
Robert
To halltech trap vs stinger
