fog light replacement
Old Nov 14, 2006 | 11:35 AM
beefaronie's Avatar
beefaronie
Default fog light replacement
Is there a write up on how to replace a burnt out fog lamp? I did a search but could not really find any info.
Old Nov 14, 2006 | 11:41 AM
bighank's Avatar
bighank
Default fog light
GM Manual says take off the closure panel UNDER the fog light with about 6 screws. DON'T have to do that
Open your headlights. Take off the plastic shrouds with 3 small screws each.
REACH IN and twist COUONTERCLOCKWISE and then pull.
I used 885 bulbs (50 watt) not the 889 or 893 bulbs (37 watt) less than 5 bucks at local auto supply.
WHAT A DIFFERENCE. Re aim em too, they are probably too low.
Use a #15 torx and park near a wall or your garage door. Can't aim horizontally but just vertically. Use low beam headlights as a guide/ BIGHANK
Old Nov 14, 2006 | 11:50 AM
beefaronie's Avatar
beefaronie
Thanks!!
Is it safe to switch to the higher watts? Any fire risk?
Old Nov 14, 2006 | 01:00 PM
SPIVET's Avatar
SPIVET
Good question. I wouldn't do it without knowing for sure.
Old Nov 14, 2006 | 03:26 PM
bighank's Avatar
bighank
Default fog lights
Mine have been in over 2 months. 37 watts draws about 3 amps 50 draws just over 4 amps. The wires look like #16 or so good for at least 10 amps. (Volts X Amps = Watts for DC) The bulbs ALL get HOT as H###. So I dont think the 885s do more than light up the road more.
I moved my 37 watt bulbs to my Montana which had 880 bulbs (only 27 watts) That made a difference too. Always run low beams with the fogs on. More people see me and I can see more. BIGHANK
Old Nov 14, 2006 | 03:52 PM
Oldvetter's Avatar
Oldvetter
I have been using 885 bulbs for over 3 years (all the time) with no problems. I aimed at bottom of low beam pattern. BIG IMPROVEMENT !
Old Nov 15, 2006 | 01:49 PM
bighank's Avatar
bighank
Default HEY ase aliens on this thread?
OLDVETTER
How did you get most of my reply about aiming the lights using a #15 torx wrench.... Mysterious to me. BIGHANK
Old Nov 19, 2006 | 09:16 PM
Oldvetter's Avatar
Oldvetter
OLDVETTER
You can copy any text and paste it anywhere.
Old Nov 19, 2006 | 11:31 PM
ALLEGRO's Avatar
ALLEGRO
Old Nov 19, 2006 | 11:34 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Here is a post from a couple of weeks ago on how to change 'em up.
http://forums.corvetteforum.com/show....php?t=1541032
To fog light replacement
