Ls?
Old Nov 14, 2006 | 12:57 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Ls?
What exaclty does "LS" stand for? I am sure someone can educate me on this.
Thanks,
Micah
Old Nov 14, 2006 | 02:08 PM
BlackZ06's Avatar
BlackZ06
I'm assuming you're referring to the engine RPO codes LS1 and LS6 in the C5 Corvettes ....
LS doesn't "stand" for anything.
In the early 1960's GM started using a 3 position code for "Regular Production Option" (RPO) identification.
Generally, codes starting with an L in the Chevy line are engines ... and since the code can be a combination of letters and numbers, previous Corvettes have had engine RPOs such as L88, LS1, and LT5.
Generally, RPO's starting with a Z are "performance" options (or option packages). Hence in the 1960s a package was offered on the Corvette called Z06, and in the Camaro line there was the well known Z28 package.
A last example is codes starting with U as these are generally radio/entertainment system options.
Old Nov 14, 2006 | 02:12 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I didn't think that LS stood for anything either, but I was curious and wanted to ask. Thanks for the reply.
Old Nov 14, 2006 | 03:24 PM
02MillenniumVette's Avatar
02MillenniumVette
Its stands for Lightning Speed. So far it only comes in stages 1, 2, 6, and 7.
Old Nov 14, 2006 | 03:38 PM
jrose7004's Avatar
jrose7004
To Ls?
