Dumb ?
Old Nov 15, 2006 | 04:02 PM
photoguy's Avatar
photoguy
Default Dumb ?
I will be getting new tires for the first time. I want to be sure the tire dealer does this right.
What kind of lug nut wrench should he use and do they need to be torqued when put back on?? I have stock chrome wheels.
Thanks for the input.
Old Nov 15, 2006 | 04:05 PM
C6NRED's Avatar
C6NRED
Just make sure they use a thin wall socket to take them off and put them back on, and then all lugs should be torqued to 100 ft/lbs.
It should not be necessary to have anything retorqued in a couple of hundred miles if you stayed with your old wheels, but new wheels need to be retorqued at that time.........
Old Nov 15, 2006 | 04:13 PM
photoguy's Avatar
photoguy
Thanks PD. I will make sure they don't screw it up. You can't trust some of these guys.
Old Nov 15, 2006 | 04:15 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
A good tire place will step them up from 50 ft/lbs to 75 to 100...
Peace
Chip
__________________
..................Click for
Old Nov 15, 2006 | 04:18 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
You don't have stock chrome wheels, there were no chrome from the factory.
As ws said ask them to hand torqued to 100 ft/lbs
Old Nov 15, 2006 | 06:32 PM
kevin40zx's Avatar
kevin40zx
I think you should be worrying about the outer rims of wheels getting scratched when they mount the new tires.
Watch'em, they will f*** ya.
Old Nov 15, 2006 | 07:09 PM
Vega$Vette's Avatar
Vega$Vette
You probably have polished thin spokes. Tell them "DO NOT USE AIR IMPACT WRENCHES ON MY WHEELS PLEASE!"
Old Nov 15, 2006 | 07:17 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Peace
Chip
Old Nov 15, 2006 | 07:24 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Originally Posted by FactoryRaceCar
Old Nov 15, 2006 | 08:20 PM
mitchcole's Avatar
mitchcole
I just took off the wheels, threw them in the truck and went to America's Tire. I don't trust anyone. I've had overtorque on my previous Honda (but then again - it was a honda) and screw up the rotors.
The guys who change oil and install tires are not mechanics.
Old Nov 15, 2006 | 09:19 PM
wingz25's Avatar
wingz25
Make sure the tire guy knows how to deal with the tire pressure sensors. He should know to loosen the inside bead first then fish the sensor out after he lets it fall into the tire by loosening the valve stem. Now that the sensor is removed, he can safely remove the tire the rest of the way without damaging the sensor. Just my .02.
Old Nov 15, 2006 | 10:26 PM
The shop can use a four way wrench (19 mm end) to take the lugs off. Just tell them to be careful with the lug wrench. When putting them back on, have them hand torque them at a staggered amount - first 60 ft/lbs, then 80, then finally 100.
Old Nov 16, 2006 | 08:11 AM
JeepTJ's Avatar
JeepTJ
Peace
Chip
That's how I do mine.
To Dumb ?
