Headers installs
Old Nov 17, 2006 | 10:25 PM
02canavette's Avatar
02canavette
Default Headers installs
Where is a good place in the Houston area to have some headers installed? I know COH will do a good job, but is there another place that can do the same type work and are dependable as well? Also, how long does it take (typically) to do the install? Thanks.
Old Nov 17, 2006 | 11:08 PM
Brad@RevXtremeAutoSports's Avatar
I will tell you that you get what you pay for. I just helped out a friend that had a crappy header install and he had to replace the rear o2 sensors and rewire it too due to a rush install. COH has a splendid reputation here. Spend the extra few dollars and have it done right if you are not doing it yourself. What money you save now, you'll spend it in the long run. Good luck JMO
