Vararam quality
Old Nov 18, 2006 | 05:07 AM
ryan.swift's Avatar
ryan.swift
Default Vararam quality
A mechanic told me that i should not install a vararam CAI i purchased because it will allow sand into the engine because it does not seal "as good as the factory" is this true? if so, what can i do to prevent this?
Thanks,
Swifty
Old Nov 18, 2006 | 05:21 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Yea the vararam is lacking in quality compared to other filters. IF you spend your time, you can adjust it so it will fit correctly, however this takes time and a perfectionist.
If you're looking for a quick and easy install, look else where. If you're looking for the best performing intake, you might consider the vararam.
Old Nov 18, 2006 | 06:02 AM
Patman's Avatar
Patman
Mine seals just fine, I get my oil analyzed after each oil change, and one of the things they can detect is if too much dirt is getting into the engine.
I too was a bit worried that I'd see a higher amount of dirt get into the engine, but after getting back my first oil analysis after the installation, I'm no longer worried. My engine wear numbers are still very low and so is the amount of dirt getting into the oil.
Just be sure the filter is well sealed off when you install the Vararam, with no open gaps. That holds true for any aftermarket air induction though.
Old Nov 18, 2006 | 06:33 AM
jdmvette's Avatar
jdmvette
Night Owl for life
if you're looking for the highest quality-best performing intake, check out the callaway honker.
Old Nov 18, 2006 | 08:52 AM
rws.1's Avatar
rws.1
Ignore the mechanic and use Cajundude 's install instruction in the archives...
Old Nov 18, 2006 | 11:56 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I am thinking of replacing my vararam with a honker. If the honker was out when I got my vararam I would have picked the honker.
Old Nov 18, 2006 | 12:11 PM
jbauch357's Avatar
jbauch357
I had the VaraRam and took it off in favor of a Honker as soon as possible, couldn't be happier with the Honker (except maybe the price...).
Old Nov 18, 2006 | 12:52 PM
TomZ's Avatar
TomZ
The stock filter works fine for me - no worries and I've got plenty of power.
Old Nov 18, 2006 | 12:55 PM
BanditDude's Avatar
BanditDude
A newer unit will seal just fine with the gray or (better) green filter. They may not be the eye candy that many want under their hood, but it works. Most of the bad reputation they received was when they came with a cheaper foam filter. When installing mine, I also followed Chuckser's advice and left the inside bolts out of the fog light shrouds. It allowed me to align everything much easier.
Give it a try. You'll love it.
Old Nov 18, 2006 | 01:35 PM
Patches's Avatar
Patches
Below is a shot of my throttle body after several thousand miles with my Vararam. There was no dust, residue nor any other dirt or sand on it when I wiped it with a clean rag after taking this shot so you tell me. I have the original Vararam with the foam Baja filter.
Old Nov 18, 2006 | 03:33 PM
zeevette's Avatar
zeevette
I just got a Vararam, but havent' yet installed it. I have put it together since I was kind of worried after hearing years of bitching about the quality. OK, it's alot of plastic ducting, not German steel, but still appears to seal well, and be of sturdy construction. I'm not disappointed. I got it from a vendor here, Corvette Garage. First rate service, and on sale, too.
Old Nov 18, 2006 | 05:52 PM
Brad@RevXtremeAutoSports's Avatar
I will be installing one on mine over Thanksgiving with video documentation. I'll let you know how it goes.
Old Nov 19, 2006 | 09:27 AM
Patman's Avatar
Patman
For those that want a bit more horsepower though, the Vararam is the way to go. Where else are you going to get a 3 tenths/3 mph improvement in the quarter mile for under $300?
To Vararam quality
