C5 Underside Bumper Scratches
Old Nov 18, 2006 | 11:04 AM
Dave Kitch's Avatar
Dave Kitch
Default C5 Underside Bumper Scratches
I noticed a lot of scratches on the forwrd side of my Y2K front urethane bumper. I have installed the Elite Engineering roller kit in the front support bars that will protect the bars. I'm also careful not to pull over low parking butments. Maybe this is an inherent problem with the low front of the C5s?
The scratches are in the clear coat but deep. I used a buffer withsome mild compound to clean these up a little.
Regards,
Dave K.
Old Nov 18, 2006 | 11:25 AM
The roller bumpers help, but there will be some things that are just going to scratch the fascia if you are unlucky enough to run into them. With the C5 sitting so low, it's hard not to occasionally run into something.
Old Nov 18, 2006 | 11:42 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Amen! And when you drop that puppy down on the bolts, it's even worse.
Old Nov 18, 2006 | 11:50 AM
fixvet's Avatar
fixvet
I too have the rollers........and deep scratches under the nose. However, since only drunks crawling around on their hands and knees actually see them, I just painted them in with the proper touch up paint.
No one ever notices them now, even me! I like!!
Old Nov 18, 2006 | 01:02 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
They all do that.
Old Nov 18, 2006 | 01:39 PM
R Devil's Avatar
R Devil
I've done it so many times, I'm thinking of installing a lift kit.
Old Nov 18, 2006 | 04:10 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I think they come off the car carrier like that. I place the scratches in the C5 "patina" catagory.
Old Nov 18, 2006 | 11:02 PM
silverbullit99's Avatar
silverbullit99
good one about the drunks,, I agree just some touch up paint will do fine..!
Old Nov 18, 2006 | 11:36 PM
DngrZne's Avatar
DngrZne
If you lower the car enough you will never be able to see them. Also, I've found I can rent the car out to paving companies needing to scrape the yellow stripes off the pavement
To C5 Underside Bumper Scratches
