Advice Needed on Purchasing C5
Old Nov 18, 2006 | 05:59 PM
GlobalFootPrints's Avatar
GlobalFootPrints
Cruising
Default Advice Needed on Purchasing C5
I am planning on purchasing a C5 – most likely a year 1999-2001 and am looking for some answers to a few questions. I would greatly appreciate any advice from you experts.
Questions:
1) Typically when any manufacturer introduces a new body style it takes 1-3 years for the manufacturer to work out all the kinks. What is the first year that all the kinks were worked out of the C5? What are the problems that I should look for on the first couple of years?
2) Is there a web page that I can get a list of all the recalls and notices from Corvette for the years I am considering?
3) What are the big ticket maintenance items that need to occur and at what mileage. (ie. timing belt)
4) What big ticket items have failed on your car (oil pump, water pump, alternator, etc.)? What is the model year of your car, what was the mileage when it occurred, and how much did it set you back?
Are there any other things that I should consider?
I am most interested in a convertible, in Red, Yellow, or Blue with a light colored interior and top (black interiors just don’t work in TX – you burn yourself when you sit in them).
Thank you for any advice you can provide!
Old Nov 18, 2006 | 06:14 PM
toxdoc's Avatar
toxdoc
Suggest you check out the sticky at the top of the page. It is very detailed, and covers many of the questions you've asked, several you haven't, and many you should ask. Welcome to the forum!
Old Nov 18, 2006 | 08:24 PM
I've got some Word files I can send you if you PM me your e-mail address.
So far, the big ticket items I have had repaired on my car are as follows:
- Rings replaced due to excessive oil consumption. (Fixed under warranty) Happened at about 11K miles.
- Rear differential seal leaks (3 times). (Fixed under warranty). Last time happened at about 22K miles - car now has 32K on it.
- Seal between tranny and differential leaked. (Fixed under warranty - cost to warranty company - $650). Happened at 25K miles.
All of these items fai
The differential seal leaks have been the most troublesome to get fixed obviously, but looks like they have it stopped at least for now. Been almost three years since the last leak.
I think you'll find that for the most part, the same annoying problems that happened to the early cars still happened to the later ones (referring to the column lock issue, differential seal leaks, etc).
The C5 is for the most part pretty reliable. Just check whatever car you are looking at over carefully and get a service history if you can.
Old Nov 19, 2006 | 12:59 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Here something that might help you out.
All of this information was collected from the Corvette Forum message board, so do not take it as absolute gospel. However, it should be somewhat close.
1997
Completely new, redesigned Corvette. Base (FE1) and Z51 (FE3) suspension packages.
All Z51 cars include: Power Steering Cooler, xx, xx, ??
97-00 C5 LS1's produce 345 HP @ 5600 RPM and 350 Ft Lbs of torque @ 4400 RPM.
1998
Convertible becomes available
Active Handling becomes available late in year
The two slots of a 1998 (and possibly late 1997s) curve toward the rear at the bottom. (versus straight down)
1999
26# injectors substituted for 28#
Fuel pump revised to reduce noise
FRC "Fixed Roof Coupe" aka the hardtop, becomes available. All FRC's are MN6 (6-speed) cars with the Z51 suspension package, and are about 60lbs lighter than coupes.
HUD introduced
only one line in driver's side fuel rail cover (no fuel return line?)
Power telescoping wheel becomes an option
? Steering hardware changed to combat wandering
door sill trim plates added
2000
Millennium Yellow available
? "Thin Spoke" versus "wagon wheel" design wheels become standard.
Pup cats added to CA models for LEV emissions requirements (5hp loss relative to 97-99)
Steel swaybar endlinks instead of plastic on Z51 equipped cars
Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
No keyhole on passenger side doorhandle
Passenger airbag 'off' switch added to console (light by TC/AH button)
2001
return to 28# injectors for all models.
Second Generation Active Handling
Nassau Blue discontinued
Alternator 'clutch' pulley added on A4 cars
New soundproofing + foam in all cars
Smaller keyfob
electrochromic dimming rearview and driver's mirrors
lighter AGM battery
Thickness + Material in vert change
Chrome exhaust tips for coupe + vert
85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
All Corvettes now have the LS6 intake manifold
All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
Hardtop/FRC discontinued
Pup cats added to all models
Stronger synchros in all transmissions
Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
metal valvestem caps (late year)
Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
Introduction of the Z06, which has as differences:
hardtop body style
rear brake ducting
screened inlets on front fascia, without foglights
F1 supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
new LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
Titanium exhaust system
lightweight windshield
New, stronger clutch with redesigned master + slave cylinder
Stronger rear differential (shotpeened ring gear)
Red brake calipers (otherwise identical)
Trans overtemp warning light on DIC
6500 redline gauges with special checkering + Z06 font
redesigned PCV system to help combat oil burning
Red LS6 Fuel Rail Covers (FRC's)
FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
Z06 Changes:
Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
Less restrictive intake airbox lid
Descreened MAF
Removal of pup-cats (total with changes = 405hp)
Z06 shocks revised with less rebound for better launching
Z06 brake pads revised for better stopping (generate more dust)
Lighter, sodium filled valves w/ stronger valvesprings
higher tension rings installed to prevent oil burning problems
slight piston redesign *
clutch strength upgraded.
HUD available on Z06 (not avail '01 model year)
Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
Electron Blue color offered
Steel endlinks changed to aluminum
Aluminum automatic transmission cooler case (all models)
AM/FM stereo with in-dash CD player now standard on Coupe and Convertible
AM/FM/Cassette only available with 12-disc CD changer on Coupe and Convertible
2003
Late model-year new fuel system design from C6's
2003 anniversary edition with Anniversary paint and decal option.
2004
Z06 shocks further refined. Accompanying upper front control arm bushing, and rear swaybar bushing changes.
2004 Commemorative Editions. CE Z06 comes with carbon fibre hood and has decal package.
Old Nov 19, 2006 | 01:28 AM
Bill Baird's Avatar
Bill Baird
Originally Posted by Stock Man
...The two slots of a 1998 (and possibly late 1997s) curve toward the rear at the bottom. (versus straight down)
This keeps appearing in these lists, but no one can ever explain what two slots they are talking about. Does anyone know what slots (or, better yet, can anyone provide pictures)?
Bill B.
Old Nov 19, 2006 | 02:10 AM
RIJVETTES's Avatar
RIJVETTES
Maybe the 2 side gill slots. Anybody got pictures to compare these on early and late model C5's? Jim
Old Nov 19, 2006 | 08:29 AM
Bill Baird's Avatar
Bill Baird
To Advice Needed on Purchasing C5
