Lowering my car
The rear lowered easily. I'm having a tough time lowering the fronts. The tech articles say the bolts should turn relatively easily, especially if I relieve some of the pressue via a jack under the spindle.
The car is on jack stands placed under the front and rear cross members and I'm using the wood blocks just like I'm supposed to.
I'm using an 6" 10mm box wrench. Should I use a longer one to get more leverage? The bolts just dont seem to want to budge.
I'm 99% sure I've got the right bolts. They are the ones coming up through the spring and there is/are rubber bushings between the spring and the A-frame. It's seems odd that I dont see the other end of the bolt. Where does it go? Into the lower arm?
Thanks for your help.
http://forums.corvetteforum.com/show...on+stock+bolts
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Below are a couple of pics to help you along. The method I used was to have the car jacked on jack stands, and then put a bottle jack with a towel on the pad to protect the spring under the spring. Then I jacked up the spring until the tension was off the bolt and I could work it loose carefully until it started turning. Back it off as much as you like and then lower the car back to the ground. It will take ~100 miles of driving or so for the car to fully settle after lowering. Get a 4-wheel alignment after that.
I was putting the jack under the control arm not the spring.
Thanks to you 5 minutes later I got it right.
Lifting the spring made all the difference.
Now just waiting for the calipers and I'll put it back together and get some pics..
