Turn lamb replacement
Old Nov 20, 2006 | 05:16 PM
bobbaker's Avatar
bobbaker
Default Turn lamb replacement
I'm having a difficult time understanding how to replace the front turning lamb. I sure would appreciate any help. Thanks,
Old Nov 20, 2006 | 05:34 PM
eec8059's Avatar
eec8059
If you're referring to the front turn signals, you must remove the plastic cover from the under side (six screws: 4 from the bottom side, 2 inside the wheel well) from the appropriate side. There is one in each side directly in front of each wheel. Once that has been removed, move the brake duct aside and reach for the bulb. If you're going to replace the turn signal itself, there are 3 (I believe)screws to undo. Sliding the car on ramps makes life easier. Good luck.
Old Nov 20, 2006 | 06:30 PM
stingray4me's Avatar
stingray4me
Default lamb 4 ya
http://cellar.org/pictures/lamb.jpg
Old Nov 20, 2006 | 07:19 PM
Vettman 1's Avatar
Vettman 1
Old Nov 20, 2006 | 07:24 PM
Old Man in a C's Avatar
Old Man in a C
Cruel
Old Nov 20, 2006 | 07:49 PM
kevin40zx's Avatar
kevin40zx
I believe when I replaced mine I manually opened the headlight, then removed the plastic molding on inside of headlight, then slipped my hand down in there and turned the bulb connection 90deg. and popped it out. If I also remember correctly this is a pain in the butt the first time. You get the hang of it after a few times though.
Old Nov 20, 2006 | 08:06 PM
Vega$Vette's Avatar
Vega$Vette
Is it a racing Lamb like this?
Old Nov 20, 2006 | 09:38 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Just to funny!! But I do agree with the going in by way of the headlight.
Old Nov 20, 2006 | 09:44 PM
C5naples's Avatar
C5naples
You guys crack me up
Old Nov 20, 2006 | 09:47 PM
gltrap54's Avatar
gltrap54
If she ain't puttin' out, I'd replace er' too!!!!!!!!!! Had that problem with an ex-lamb & by golly she's gone!
To Turn lamb replacement
