Need part number help please
I am in the process of looking for a Z06 sway bar kit for my 04.
As I go through the Fred Beans site (for one) they dont show a Z06 specific sway bar, just three different types of bars.
GMPartsDirect has a kit that includes the 2 bars, bushings, and the endlinks. They call it the Z06 kit.
Could someone here please get me the part numbers for the Z06 sway bars, bushings, and endlinks?
Thanks much for your assistance.
Shaft, Frt Stabilizer Y37 01-04 (FE4) GM # 10419094
Shaft, Rr Stabilizer Y 01-04 (FE3, FE4) GM # 10424743
I don't have the latest P/Ns for the bushings and endlinks. Also, all model year 2002 and later C5s came from the factory with the aluminum endlinks so you shouldn't need these unless yours are worn or damaged. Fichtner Chevrolet also has the C5 Z06 Stablizer Bar Package that you can order with or without the endlinks:
Fichtner On-Line Catalog (See second item down.)
What suspension does your car have now? Note in the P/Ns for the bars above that the Z06/FE4 and the model year 2001 and later Z51/FE3 suspensions share the same rear stabilizer bar. So if your car has the Z51/FE3 package, you would only need the front bar and bushings.
If you give Fred Beans or Fichtner Chevrolet (both Forum supporting vendors) a call and let them know what suspension your car has now, either should be able to provide you with the P/Ns and only those parts that you need to upgrade your suspension.
HTH and good luck with the upgrade.
