Searched for a thread I saw some time ago about fitting 2006/7 ZO6 rear fender flare moldings on a C5.
Anyone??
I am in the process of fitting a pair now and wonder about how to attach them. 3M double sided tape?
Fred
the provided double sided tape, push pins, and a whole lot of hand shaping are what gets these to work.
I hear you on the hand shaping. Worked on one side for nearly 2 hours and have just about got a good fit.
Hope mine look as good as yours!
Thanks for the post.
Fred
Fred
Used doublesided tape and a couple of screws top and bottom to secure the flare.
Just a heads up if you're considering the front flares.......They wont work. The flare is incorporated into the fender liner and even if you cut it off, the radius is different at the bottom of the fender. I know this from experience.
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Not the greatest shots of the flares but if you look real close, you'll see that I "thinned" my out by about 3/4" to give it a sleeker profile. Just comes down to personal preference...they look good either way
Put the moldings on today. RH very little fitting, LH much. I checked out the ZO6 fronts and as noted above they have a big piece that goes into the wheel well. I used 3M double sided tape and some contact cement at the very top & bottom. Ecklers sells front & rear ZO6 style flares made for the C5, I ordered a front set today.
GM part # for the rears 15818636 & 37; $40 each , but with my club discount were $30.
Thanks for all the posts.
Fred
