Coupe to a Vert
Old Nov 22, 2006 | 02:10 PM
Tom Porter's Avatar
Tom Porter
Default Coupe to a Vert
Has anybody done the conversion from a coupe to a convertable? If so would you do it again and what is the cost for all the parts?
Old Nov 22, 2006 | 02:25 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
I doubt it's practical. Sell the coupe and buy a 'vert. For one thing, a 'vert has a different frame.
There have been a few conversions of Z06 cars into 'verts, but that's to get a car you can't get any other way. Plus, the Z06 already has the 'vert frame. I believe these conversions are in the $20k range.
Old Nov 22, 2006 | 02:27 PM
Bill Baird's Avatar
Bill Baird
What are the differences in the frames?
Old Nov 22, 2006 | 02:43 PM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
I can't give you any of the technical aspects of it, but the Vert does not have the resistance to the torque provided by the roof members of a coupe. As such there would have to be something provided for in the undercarriage to keep the frame from twisting more on a vert because there is no roof to do that.
Old Nov 22, 2006 | 02:58 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
All C5's, whether it's a Targa Coupe, Fixed Roof Coupe or a Convertible, have the same frame.
Old Nov 22, 2006 | 03:01 PM
Bill Baird's Avatar
Bill Baird
The car was designed as a convertible, and so the frame did not need any additional reinforcement when the convertible joined the lineup in 1998. I've always been under the impression that the C5 frame was the same regardless of the bodystyle.
Old Nov 22, 2006 | 03:02 PM
Bill Baird's Avatar
Bill Baird
Old Nov 22, 2006 | 05:02 PM
BanditSRT's Avatar
BanditSRT
GrayC5's Avatar
GrayC5
Yes, all three (coupe, vert and FRC/Z06) share the frame. However, the vert does have some extra bracing in the trunk area. Too, the vert and FRC/Z06 share most of the same body panels (rear quarter panels, trunk lid, etc.) that the coupe does not. There was a member here several years ago that detailed how he converted his model year 2003 AE vert into a FRC. For the most part as he described it, the job involved the unbolting and bolting and the changing out of parts to include to the extra bracing in the vert trunk area to accommodate the FRC top. As best I remember, he did all the work himself (except possibly for the painting of the FRC top) over the course of just a few days using all OEM parts. Too, I believe the FRC top from the factory possibly is glued in some areas. If I remember correctly, he did not do the gluing so that he could go back and forth from the vert to FRC fairly quickly.
If you can go from a vert to an FRC, I see no reason why you couldn't go from an FRC to an vert. However, as the coupe is quite different in this regard, I would think that changing it into a vert would be much more involved and much more expensive.
Old Nov 22, 2006 | 05:30 PM
HummelS's Avatar
HummelS
Not sure about the bracing in the trunk of the vert, but the main thing that needs to change, once you've removed the hoop, is that the rear fenders are slightly different between the coupe and vert/z06. The coupe fenders will either need to be trimmed, or replaced with fenders that will accomodate the trunk and tonneau cover. See pic for the difference where the fender meets the roof of the Z06 - a convertible fender is identical.
I knew a guy in San Diego a couple of years ago who did the conversion. He said it wasn't too bad. The car drove fine - no flex. I'll try to find a pic.
Here's the car in question - he even hand-laid his own hardtop for it (surfboard maker). Now that I think of it, both the Z06 and the 'vert will need some kind of cross brace to support the trunk hinges....
Old Nov 22, 2006 | 05:42 PM
bonnell's Avatar
bonnell
The C4 had frame dirrerences but not the C5.
Old Nov 22, 2006 | 06:28 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
Interesting. I was just going by what's in the Z06 forum sticky here.
Old Nov 25, 2006 | 11:35 AM
OrangeVegaGT
If all the frames are the same I wonder why GM will not make a Z06 vert?
Old Nov 25, 2006 | 11:48 AM
JH's Avatar
JH
Differences in frames and bracing aside, this would be costly and what would you have at the end? A former-coupe conversion-to-convertible, fine, but if I want a coupe I don't want the car, if I want a convertible I will find a good one, and I will be completely suspect of the conversion. You'd take a bath on resale and never recoup (pun intended) the cost of the conversion.
If ya want a convertible, go trade for one!
Old Nov 25, 2006 | 11:55 AM
HummelS's Avatar
HummelS
Generally, I agree with this - the car I showed earlier in this thread is one I had listed when I worked for The Vette Net. When I would get an inquiry on the "convertible," and explained the circumstances, people lost interest quickly.
Just because you "can," doesn't mean you "should."
Old Nov 25, 2006 | 12:24 PM
Patches's Avatar
Patches
PaceThis is in the process of this conversion right now. Check out post#7 in this thread.
http://forums.corvetteforum.com/show....php?t=1528503
Old Nov 25, 2006 | 12:28 PM
I have a tendency to agree - before I would go to the expense of a conversion, I would just go buy a factory convertible and be done with it.
Old Nov 25, 2006 | 02:09 PM
inoyourtrippn's Avatar
inoyourtrippn
i would just buy the roadster kit that i have seen. my 2 cents
Old Nov 25, 2006 | 02:59 PM
sailohio's Avatar
sailohio
BTW I saw a Z06 FRC at Carlisle that was converted to a vert. The car was rolled and bought by the owner with a salvage title. Rather than repair the top he cut it off. The conversion looked terrific.
To Coupe to a Vert
