02 Sensor plugs?
Old Nov 22, 2006 | 06:34 PM
fright88's Avatar
fright88
Default 02 Sensor plugs?
Ok so I am having problems with my passenger side front 02 sensor. I went and bought a new one from Autozone but it has a flat black plug. The plugs on my stock 02 sensors are square and white I believe. Does anyone know where I can buy the sensors with thesquare connector? Or is there an adapter I can buy? Thanks.
Jason
Old Nov 22, 2006 | 06:39 PM
LoneStarFRC's Avatar
LoneStarFRC
Kinda sounds like they sold you the wrong one. Maybe a late/early year production change? Make sure they know you're looking for a front, etc. Not sure. Dig into it more. I'm sure you'll be able to get the right one.
HTH,
Robert
Old Nov 23, 2006 | 10:43 AM
Brad@RevXtremeAutoSports's Avatar
take your original if you have it with you and match it up. also, try your local dealer if you need it ASAP. Or if you can wait, I know Fred Beans will hook you up right as I helped out a friend install his. Good Luck
Old Nov 23, 2006 | 10:45 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Nov 23, 2006 | 12:38 PM
ICUALL's Avatar
ICUALL
Flat plug = rear O2 sensor ...
anthony@lgmotorsports.com Lgmotorsport can hook you up with adapters....
To 02 Sensor plugs?
