Water Leak
Old Nov 22, 2006 | 09:32 PM
3 vettes's Avatar
3 vettes
Default Water Leak
My Left And Right Rear Compartments Get Wet Inside When It Rains Hard.nothing On Top Or In The Center Comp.is There A Common Place That Water Gets In There?my W/strip Is Good And There Is Now Wetness On Top Of The Compartment Just Inside The 2 Smaller Ones.help Please
Old Nov 22, 2006 | 09:48 PM
DngrZne's Avatar
DngrZne
On my car I had problems with water getting in through the seam where the various inner body panels were bonded right behind the passenger door. If you take the fenders off you will see several panels that come together right below where the rear deck gutter drains. The water was leaking in there, under the rear speaker housing and across the fiberglass floor of the trunk, underneath the carpeting, and into the rear compartments. You may want to pull all the carpeting out of the back of the car and hose the outside down really well and see where the water is coming from.
Chris
