Oil Pressure?
Old Nov 24, 2006 | 10:46 AM
fright88's Avatar
fright88
Default Oil Pressure?
What is normal oil pressure readings for idle and normal driving? I have an oil light on constantly after installing my long tubes. I checked and my engine seems to have plenty oil. Just want to make sure I am not missing something thanks.
Old Nov 24, 2006 | 11:13 AM
Patman's Avatar
Patman
I typically see 30psi at idle (in drive with an automatic, 6 speeds will have a higher idle oil pressure) and about 44psi at 70mph (2000rpm) This is with 200F oil temps.
Old Nov 24, 2006 | 06:20 PM
That's about what mine shows. 2000, 6 speed here.
Old Nov 24, 2006 | 06:31 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Nov 24, 2006 | 06:36 PM
jerrymcb's Avatar
jerrymcb
Are you talking about the HUD? If so you just have to
change the display to what you want to see.
Old Nov 24, 2006 | 07:18 PM
fright88's Avatar
fright88
Ok maybe I am being paranoid. But in my HUD I see a oil can looking thing in the top left. I don't remembr seeing it in the HUD before the long tube swap. But my dipstick says it is full.
Old Nov 24, 2006 | 07:20 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Right On the Money
Old Nov 24, 2006 | 07:51 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
The oil can is showing in the HUD display because you disconnected your battery to install the headers (thus causing the display to revert to "default"). Just press the Page button until you get the display you want.
Old Nov 24, 2006 | 09:14 PM
rrichar2591's Avatar
rrichar2591
The oil can in the HUD does not mean an oil problem. It's just telling you that the display selected is to monitor oil pressure. As the other post notes, just use the page button to select what display you want to see.
Old Nov 24, 2006 | 09:22 PM
fright88's Avatar
fright88
Ahh thanks. I am a putz. LOL I am still getting use to this car. And I hadn't played with thie hud much before.
To Oil Pressure?
