c 5 spare tire
Old Nov 24, 2006 | 02:31 PM
limousin's Avatar
limousin
3rd Gear
Default c 5 spare tire
I took my runflats off, because I could not stand the ride.
Has someone tried to find a donut spare tire and rim from a junk yard that would fit and get you off the road. Any idea of what brand and size that would fit?
Old Nov 24, 2006 | 02:42 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I've read that a few people have machined about 1/16 inch out of the center hole on a new GTO spare to fit their C5s.
Old Nov 24, 2006 | 02:45 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
First post since 2001? Welcome old timer/newbie!!!
I wouldn't bother with a donut spare - good luck finding one that will clear both the front and rear calipers, have the right offset so it doesn't rub and the right bolt pattern (120mm). Not to mention that you will need to start carrying a jack too.
Just get yourself a small 12v compressor - I bought mine at Wal-Mart for $10, a plug and patch kit, and some other stuff like something to kneel/lay down on, a flashlight and maybe a pair of Mechanix gloves.
Tthe other route you can take is a charged up cell phone and AAA.
Again - welcome to the forum!
Old Nov 24, 2006 | 02:46 PM
ronnie948's Avatar
ronnie948
Cruise-In III Veteran
Default Flat fix ?????
Probably a tire repair kit from a Z0-6 would work. A can of "FIX A FLAT??? I think any C-5 would be hard to jack up along side of the road.
Ronnie
Old Nov 24, 2006 | 03:13 PM
jrprich's Avatar
jrprich
Take a look
http://cgi.ebay.com/ebaymotors/ws/eB...2776221&rd=1,1
Old Nov 24, 2006 | 03:24 PM
bonnell's Avatar
bonnell
Ronnie
My understanding is taht fix-a-flat ruins your sensors. I bought one of these:
http://www.tirerack.com/accessories/...tkit/index.jsp
This is a compressor and has a builtin sealant. Use as a compressor for tires and if you have a flat, inject the sealant while using the compressor (sealant is built in).
Old Nov 24, 2006 | 03:30 PM
cuspid's Avatar
cuspid
Gto spare clears both front and rear calipers, you must shave about 1/16 of aluminum out of the center hole.
Old Nov 24, 2006 | 03:31 PM
cuspid's Avatar
cuspid
Search ebay 04 gto, last I looked there were 2 on there.
Old Nov 24, 2006 | 05:12 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
if "fix-a-flat" ruins your tire pressure monitors, so what? you don't have the run flats anymore... don't really need the tpsm's....if you use the tire rack unit you still have to "clean" the sensors so they'll function in the future.
Old Nov 24, 2006 | 05:38 PM
blacksedan87
I have to disagree with your logic, Dave. I don't have runflats or stock wheels anymore, and I still use my TPS, If anything it's more important than ever. With run flats and stock wheels, if the tire is low or flat, I could still drive on it for up to 200 miles provided I was using the Goodyear EMT's.
With the current set up - I want to know if I have a tire losing air pressure ASAP! With the current crop of Ultra low profile tires, detecting a low tire by a simple visual inspection is harder than ever. Having the proper inflation in my tires, and knowing their status could save a tire ($400 in the case of my back ones), a wheel (about $900) the car - or even my life. I'd say it's worth using what GM gave us in this case.
Also - by Federal Mandate - 100% of all vehicles manufactured after 8/31/2007 must have a tire pressure monitoring system. And to think that Corvettes had them way back in 1997......hmmmmmm.
click here to read the NHTSA ruling!
Old Nov 24, 2006 | 06:01 PM
I agree with BlackSedan87 - just get the stuff mentioned and go on your way. A cell phone can always be used to call for help if needed.
Old Nov 24, 2006 | 07:18 PM
Barrier's Avatar
Barrier
Just went the same way, non-runflats, small compressor and a repair kit.
For long trips I bought the GTO spare and I ordered a Mercedes Jack from C5Frederik a forum member.
Even with the Runflats I understand a puncture in any but the GY Runflats requires a new Tire. The 50 mile limit placed on non GY may not get to a place close enough to locate an equivalent replacement particularly on a weekend afternoon, so why bother.
If I used my car as a DD it might be another story.
Just my opinion!
Barrier
Old Nov 24, 2006 | 07:24 PM
Ta-taaa's Avatar
Ta-taaa
Heard this to. Also heard some keeping a tire repair kit with them and small airpump
Old Nov 24, 2006 | 09:51 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
I was talking to my preferred tuner today and the same question came up. He said that he found that the space-saver spare from a late F-body fits and works fine, front and rear. That's what he carries in his personal C5 on long trips.
Old Nov 24, 2006 | 10:14 PM
robsvette's Avatar
robsvette
no way jose! thats when u need it most. half the time a flat tire is a slow leak. when the pressure goes below 25 u will get the warning display meaning get the hell home
Old Nov 24, 2006 | 10:19 PM
lt1george's Avatar
lt1george
Default GTO spare
Bought my GTO spare from Pick a Part in Cleveland(ebay). Great Deal and fast shipping. The GTO mag without the donut spare tire lists for over $200.00 in the GM parts book. So $65.00 plus shipping is a steal. Save the Wave.>george
Old Nov 25, 2006 | 05:56 PM
limousin's Avatar
limousin
3rd Gear
Default gto spare
Originally Posted by jrprich
Hey thanks, for the answer. This saves me a lot of time. I already have a small sizzor jack, repair kit, and sm compressor, but I would hate to get stuck out in the sticks waiting 2wks for a replacement tire.
To c 5 spare tire
Old Nov 25, 2006 | 06:44 PM
c4cruiser's Avatar
c4cruiser
Originally Posted by gannet
... He said that he found that the space-saver spare from a late F-body fits and works fine, front and rear. That's what he carries in his personal C5 on long trips.
If you are out on a long road trip, carrying a F-body or GTO spare is one thing, finding a place for the dead standard tire/wheel is another
Old Nov 25, 2006 | 06:55 PM
Barrier's Avatar
Barrier
Interesting point about where to put the Flat Tire. Has anyone ever checked to see if there is anyway to get the Flat into the car? Hatch or Trunk lid open? Passenger seat (minus passenger)?
Barrier
Old Nov 25, 2006 | 07:08 PM
BlackZ06's Avatar
BlackZ06
Along with the issue of "where to put the dead tire" ....
Has anyone checked to see if you can get a jack under the car WHEN THE TIRE IS FLAT ???
It is tough enough finding jacks that will get under the car when the tires are inflated, I'd bet the front jacking points will be at least another inch lower with a front tire flat. I had a rear flat in my garage one time and it was a PITA getting the jack under the rear jacking point.
