Block Heater
does anyone have any experience installing these, as much as i know it goes in where your freeze out plug is, i believe, correct me if i'm wrong, and if so does anyone know the proper installation of a block heater in a '98 C5?
thanks
-Brian.
Basically the steps are:
Drain cooling system
Remove existing plug
Clean opening in the block to remove any sealant or paint.
Remove cord from heater so you are installing only the heater plug.
Apply a bead of sealant GM P/N 12346004 (or equivalent) to the heater sealing washer
Insert the heater
Tighten to 30 lb ft (40 N m)
Install the cord to the heater
Install wheel (if removed)
Fill cooling system
Pop a beer and relax .... (that's my instruction .. it ain't in the manual)
