Headers
Old Nov 27, 2006 | 12:03 AM
02canavette's Avatar
02canavette
Default Headers
I am in process of buying some headers for my C5. I see that LG is pretty popular within the forum. I was wondering if someone would enlighten me. What is the difference with the LG street series and the LG Pro headers? I would like to also get the hi-flow cats with the system. I already have a Corsa exhaust, what should I get? Money is itching my hands. Thanks.
Old Nov 27, 2006 | 01:27 AM
RebelVette's Avatar
RebelVette
Quick response in difference b/w Street and Pro:
Street - 2-1/2-inch diameter after the headers (which are 3" in Street and pros) and a different x-pipe. Build quality is just as high as the Pros.
Pros - custom x-pipe and 3" pipe all the way to the exhaust (muffler) connection.
In deciding between the 2, if you're going to keep your head/cam stock, then save your money and go with the Streets. If you expect to change these out down the road, go ahead and get the Pros.
It's really just how much money you want to spend. I went with the Streets with x-pipe and cats, and the total cost shipping incl. was $1235 (that was during a special they were running shortly after they came out). I installed them myself in about 6 hours.
Hope this helps, good luck with your search. I'm sure others will chime in with their opinions as well.
Old Nov 27, 2006 | 01:33 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
you can always call LG...they will be more than happy to talk to you about their headers
Old Nov 27, 2006 | 08:17 AM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Here's a link to LG Motorsports. (Check out some of the dyno results). Looks like a 5-10 HP difference between the Streets vs. Pros. I have the Streets with cats and Corsa Pace exhaust and love 'em.
http://lgmotorsports.com/catalog/index.php
Old Nov 27, 2006 | 01:14 PM
Arnie Guitar's Avatar
Arnie Guitar
I just did a search and found this link...
http://www.ls1howto.com/index.php?article=29
Old Nov 27, 2006 | 01:16 PM
BarneyZ's Avatar
BarneyZ
Had my Dynatech Supermaxx's installed by 21st Century Musclecars in Addison back in August. Bolted up to Corsa Tourings. Couldn't be happier with the workmanship of the headers and the install. FWW Dynatech's bolt together with super heavy flanged connections whereas the LG's use slip-fit type pipes. Some say this style makes the LG's more prone to leaks.
Old Nov 27, 2006 | 01:17 PM
jbone's Avatar
jbone
Originally Posted by 528rwhp02Zo6
I like the LG's, they make a great product...But I'm a Kooks man for life after I saw the guy who did my mods dyno test them on the same car Vs the Kooks. The Kooks had 9 RWHP & 5 Lbft over the LG's. Every car responds different though. Kooks specializes In only headers since 1962 I believe. This comparo was with 1-7/8" Headers.
I have the 1-7/8" with 3"Kooks X-Pipe/Hi-flow cats and they are great! *
Old Nov 27, 2006 | 01:47 PM
Vetteoholic's Avatar
Vetteoholic
Old Nov 27, 2006 | 02:05 PM
Arnie Guitar
I would imagine the car has to be on a lift, or how high did you have to raise the front end?
Does the engine have to be moved/unbolted/lifted to install the headers?
Thank you,
Arnie
Old Nov 29, 2006 | 11:56 PM
RebelVette's Avatar
RebelVette
Thank you,
Arnie
I lifted the car about 30 inches in the front (with multiple jack stands on 6x6 blocks). The driver's side header slides in from below, the passenger side from above.
Both went in with minimal wiggling. The only thing I unbolted on the passenger side was the valve covers (and coil packs) and the coil packs and alternator on the driver's side (see pics).
Here's a nice side-by-side
And here's the finished product.
Feel free to PM me if you have any other questions.
Jack
Old Nov 30, 2006 | 01:55 AM
wayneinvirginia's Avatar
wayneinvirginia
Cruise-In VIII Veteran
Here is an installed Dynamaxx System with long tube, hi flow cats and a x-pipe (I've already turned the clamps to the sides of the pipes).
Old Nov 30, 2006 | 10:47 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
...But you forgot the CCA Tunnel Plate
Came out nice
Peace
Chip
__________________
..................Click for
Old Nov 30, 2006 | 01:16 PM
TonyC5's Avatar
TonyC5
Nice work!
To Headers
