first the z06 and the c5 have different engines one is an ls6 and one is an ls1 the difference in a 98 c5 and a 02c5 is about 5-10 hp the fuel delivery system was changed
are the transmissions much different? I mean how much different can they be if their both 6 speed? Does on have longer/shorter gears?
the MN12 (Z06 trans) acts like a 3.90 for gears 1-2 and then like a 3.42 for the rest of the gears. The regular C5 (MN6) will act like a 3.42 the entire time. It is a fair difference at the 1/4 mile track, but that alone will probably not win or lose a race.
the Z06 beside having more power is also lighter.
I may have to settle for a 99-00' C5. Could I still make 450whp/450whtq with just bolt ons? If not, cams?
with enough money you can do make any rwhp that you want.
If you can afford it go with 01+ - some 01s have oil consumption problems. If you cant afford it then you will be happy with a 98-00 hell you are driving a vette...
yeah exactly...
Im going to go with an 00' C5 with around 90k mileage. Its official.
Ill invest in wheels, tires, head and cam package (I dont know of a good vendor for this yet), and all bolt ons and possibly spray.
First....take a look at the Sticky concerning "Weights, Measurements...." A wealth of info concerning the C5 and individuals years.
Secondly.....if your budget can handle it, go with the 01. I would always try to get the best enhancements, improvements, etc to the generation you can afford. Good luck and let us know what you end up doing.
If you can afford the '01, go for it. More HP and torque, plus a number of options that were offered or simply not available on the '98 were standard on the '01. You can get the HUD, active handling, etc on the '01.
I'll just state the basics as other's have I'm sure....In 01' the HP Is 350 up from 345/Torque is 375*6spd/360*Automatic.Up from 350. Your torque will come on 400 rpm sooner with both the MN6 and the auto. It's only written as 400rpm sooner with the auto though. I read many reports that It goes for the 6spd as well~they just dont list It for some reason.
The wheels are different and a couple of pounds lighter. STD Heads up display, chrome exhaust tips, Improved shift linkage, more options
Ect Ect.... Best magazine #'s I've seen=1998*4.8 (0-60) *11.2 (0-100)
*13.2 (Qrt.ML) *@109mph...
2001*4.5(0-60) *10.8 (0-100) *13.0 (Qrt.ML) *@110mph...
*These were Motor Trends best #'s on both cars. Every person and car Is different so It all depends. This Is just to give you an Idea *Both tests were 6spds the 02 Auto= 4.9*(0-60) 13.3 (Qrt.ML) *@106mph oh and (0-100)=12.1sec Tested with optional 3.15 ratio I hope this helps, remember~these were just Mag. Tests~
