You may want to post this in the car care section. Lots of detailers there that can offer good advice. I myself try to detail the engine approx once a month or so. I find it's much easier to keep it clean than bring it back from being dirty.
I spay an old cloth with some Simple Green and wipe down most of the easy to reach areas. I'll use some Vinyl and Rubber conditioner on the hoses. Some areas I'll have to use a Qtip or toothbrush to get to.
Others will tell you it's ok to hose the engine down with water but my own opinion is to not use and instead just keep it clean with regular cleanings noted above. Good luck.
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I myself thought about just this topic recently. And although in the past (not with the Vette) I have pressure washed boat,streetrod,lawnmower engines to clean them. I feel the Corvette has enough electrical/electronic problems without soaking the engine bay enhancing corosion in connectors and components. I'm going to go lurk around in the car care section and get some insight there.
