cut front bushings
i lowered my car and would like to drop it a little bit more. My question is what would I have to do to be able to cut the bushing? my saw is to big to fit in that area.
thanks
thanks
u have to unbolt the lower control arms from spindles and unbolt the leaf spring from the car and also unbolt the shocks so u can lower the control arms.... u have to pull the whole leaf spring from the car.
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I jacked up the end of the spring and sawed the bushings off with a drywall saw. I disassembled nothing.
Even if you do it the hard way and drop the control arm to access the bushings, there is no reason whatsoever to remove the leaf spring.
Don't cut the front bushing
you cant replace them you have to buy a whole spring assembly thanks GM you can buy this lowering kit for the C6 it is the same bolt size and thread pitch as the C5 I lowered my car and it wasn't as low as I wanted this option got me another 3/4 of an inch without cuting the bushings make sure you have a good alignment after
http://www.westcoastcorvette.com/pc-...-bolt-kit.aspx
you cant replace them you have to buy a whole spring assembly thanks GM you can buy this lowering kit for the C6 it is the same bolt size and thread pitch as the C5 I lowered my car and it wasn't as low as I wanted this option got me another 3/4 of an inch without cuting the bushings make sure you have a good alignment afterhttp://www.westcoastcorvette.com/pc-...-bolt-kit.aspx
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
thanks
thanks
I know what you mean. Before I received mine (and saw them in my hand) from the pics in the advertisments They looked like bolts with a large head. But that's not true. They have a thinner rubber head on them I would imagine as "chaffe gear" to protect the lower control arm that they contact.
Cutting the bushings potentially ruins the car for a subsequent purchaser since you have made the recovery very expensive. Currently, there is another post on the forum with a guy trying to figure out how to get a car he is purchasing with cut bushings restored to a more normal ride height.
Bill
Bill
I cut 2/3 off mine with a SawzAll. Took nothing apart. Don't see this affecting a future sale as one can always raise the front up even with cut bushings. Not as much as stock , but, still close.
Fred
Fred
Originally Posted by Ryan L
So use 2 bolts from the C6 kit and buy two longer C5s for the reas?
From: Oakville ON "Real Corvettes have folding tops..."
Used a coping saw on mine. Only cut the first ridge off which left lots of bushing rubber. There is lots of adjustment in th stock bolt if someone wants to jack it up again in future.
