Tire pressure sensor upgrade
Old Dec 1, 2006 | 10:08 PM
jrprich's Avatar
jrprich
Default Tire pressure sensor upgrade
Anyone know what it takes to upgrade a 99 to use 01-04 Tire Pressure Sensors ? What has to be swapped out or reprogrammed ?
Old Dec 1, 2006 | 10:54 PM
Bill Vett's Avatar
Bill Vett
I think it would be cheaper to purchase the correct sensors at $76.'s each, than all the computer swapping you would have to do.
Old Dec 1, 2006 | 11:29 PM
kingsey's Avatar
kingsey
OH so if i buy new c6 rims with sensors already in them? Its not going to work at all?!
Old Dec 1, 2006 | 11:34 PM
Bill Vett's Avatar
Bill Vett
If the're not 97 to 2000 sensors they won't work on your 99.
Old Dec 1, 2006 | 11:35 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
That's a big 10-4, good buddy!
You HAVE to use the 1st generation sensors with your '99.
Old Dec 1, 2006 | 11:39 PM
kingsey's Avatar
kingsey
Well.........**** i had a great deal on a rim, tires and sensors set. Should i still get them and replace the sensors?
Old Dec 1, 2006 | 11:42 PM
blacksedan87
If it's that great a deal - have a reputable tire shop swap your old sensors (assuming that they work) with the new ones, and sell the new ones here or on that auction site. The whole tire doesn't have to be removed, someone who knows how should just have to break the front bead, and swap sensors. You won't even have to have the tire rebalanced, but it might not be a bad idea, considering that the old sensors are bigger and probably slightly heavier than the new style sensors.
Old Dec 1, 2006 | 11:45 PM
kingsey's Avatar
kingsey
but man 80 bucks per rim? Thats crazy!
Old Dec 1, 2006 | 11:49 PM
jrprich's Avatar
jrprich
SHOPPING CART
Description Qty MSRP Price Your Price Core Price Total Cost
Collision Catalog - 1999 - Chevrolet/Geo - Corvette
Wheels, Wheels, Pressure sensor, Low tire, Low tire $124.95 $78.34 $0.00 $313.36
Wheels, Wheels, Pressure sensor, Nut, Nut $2.17 $1.36 $0.00 $5.44
Wheels, Wheels, Pressure sensor, Washer, Washer $2.33 $1.66 $0.00 $6.64
Total: $325.44
Well with it costing $325.44
To replace my 99 Sensors, I was curious as to what would have to be swapped out to accept the $30 sensors for the 01-04 series
Old Dec 1, 2006 | 11:59 PM
kingsey's Avatar
kingsey
That will bring the cost over 2k. Can i get brand new c6 rims and tires in 18/19 for 2 grand?
Old Dec 2, 2006 | 06:02 AM
Probably cheaper to just get the right sensors. At a minimum I would think that you would have to get a different TPS receiver in the car. With the sensors lasting up to 8 years, it's not an expense that you have to make very often.
Old Dec 2, 2006 | 08:53 AM
ytwokc5's Avatar
ytwokc5
I'm faced with replacing all 4 sensors on my 00 coupe when I replace the tires in the rims. Where's the best place to get them at a reasonable price. I know in the past Fred Beans has been mentioned... who is the contact there now?
Old Dec 2, 2006 | 09:00 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
The receiver is different on the 97-2000 as are the sensors. They are not interchangeable..........
Old Dec 2, 2006 | 12:33 PM
jrprich's Avatar
jrprich
The prices and part numbers in my earlier post above are current from Fred Beans website.
http://www.trademotion.com/pages/ind...2&pageid=10008
Old Dec 2, 2006 | 12:40 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
but I would get the tire and wheel rebalanced.
Old Dec 2, 2006 | 12:49 PM
yaknow's Avatar
yaknow
Is battery replacement a viable long term solution?
Old Dec 2, 2006 | 02:29 PM
jrprich's Avatar
jrprich
The instructions I saw on the CF seemed pretty involved and did not seem easy to reverse for a second time.
Too bad GM didn't make this a simple swap out battery
To Tire pressure sensor upgrade
Old Dec 2, 2006 | 04:17 PM
ytwokc5's Avatar
ytwokc5
Thanks!
Old Dec 2, 2006 | 04:37 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I believe the best price can be had from Bob (a Forum Vendor, so don't forget the corvetteforum discount) at House of Wheels, www.houseofwheelsonline.com
Old Dec 2, 2006 | 05:14 PM
jrprich's Avatar
jrprich
What price do you have for 99-01 sensors from Bob ?
