Air box Switch - need help
Old Dec 2, 2006 | 10:33 AM
mk8k8's Avatar
mk8k8
Default Air box Switch - need help
Hey guys,
Im just bought a z06 air box and would like to switch it with my stock 99 one. ive read a couple other posts on how to take the original one off but cant seem to understand with out some pics.
Can anyone help with some instructions and possibly some pics?
Thanks, Mike
Old Dec 2, 2006 | 03:08 PM
Blue Lion's Avatar
Blue Lion
I switched mine and it wasn't hard. I don't have any pictures. Either contact the seller or just look at what you have and take your time. There's nothing to mess up that I recall.
Old Dec 2, 2006 | 03:34 PM
lt1george's Avatar
lt1george
Default Z06 air box
Mike, Loosen clamp at air bridge, pop your two release handles on air box and wiggle the two bottom gromments off the bottom of the air box. Should come right off.Hope this helps.>George
Old Dec 2, 2006 | 05:19 PM
JUSAKD's Avatar
JUSAKD
Sometimes it is hard to get the air box off the pegs in the front that it hooks into. I think the pegs come down from the top and the air box needs to be pushed down off them. Once you do it it is easy.
Old Dec 3, 2006 | 01:11 AM
Did you buy the whole box or just the Z06 lid? If the box, follow the instructions above. If just the lid (which will fit on the stock box without removing the lower part of the air cleaner), just loosen the metal straps, take the old top half off, install the new top and then reattach the straps.
Old Dec 3, 2006 | 08:13 AM
Vettman 1's Avatar
Vettman 1
Would this provide any HP gain? I've seen the Z06 pieces relatively cheap.
Old Dec 3, 2006 | 09:36 AM
RTSVET's Avatar
RTSVET
I replaced my Blackwing with the Z06 air box w/kn filter and cant tell any difference in the 2 preformance wise.
Old Dec 3, 2006 | 11:30 AM
Blue Lion's Avatar
Blue Lion
I put on a K&N and Z06 airbox and at time Forum members told me the HP gain might 3-5. I don't notice any difference, but I've never had it measured.
Old Dec 3, 2006 | 11:37 AM
TexasMadMan's Avatar
TexasMadMan
The only difference I noticed was that my gas mileage went down and I have not changed my driving habits. Thinking about going back to the stock cover.
Old Dec 3, 2006 | 12:42 PM
hotwheels57's Avatar
hotwheels57
...when you re-install the grommets over the plastic pegs, use a light application of your favorite grease to make installation and future removal easy. I've lost two of those grommets in my engine compartment, never to be found again. They cost approx. $2.50 each at the dealership.
To Air box Switch - need help
