well, installed my HID's. i need to take some pictures to show you guys, which i will be doing tomorrow. its too cold outside right now and i cant find my digicam. what a difference this makes man. its PERFECT for me
i went with the 6000K bulb. very
EDIT: how do you aim the lights on the car? like the height of the beam. where do i have to adjust it?
ill get them up ASAP... gonna take some tonight when i get off from work, theres some nice scenery here and ill let you guys stare at them and drool... lol
Be VERY careful adjusting those lights. If they are the ones from ACA that come with the new housings they can only be adjusted using the stock adjustment screws. I broke both my housings by adjusting them and then closing them (turned off the lights). They will be high when mounted in the same spot as the stockers. If I had it to do over I would mount them low intentionally (adjust the mounting screws) prior to installation and then adjust with the stock adj. screws;especially if your car is lowered.
