Help removing the AC Compressor
Old Dec 4, 2006 | 10:35 AM
CSTYLEZ's Avatar
CSTYLEZ
Default Help removing the AC Compressor
I want to remove the AC Compressor to have it chromed, but according to my GM manuals it says I have to remove the water pump. I dont want to have to do that because everything is chromed and that would create a big mess AGAIN draining the coolant. Anyone have any tips at on an easier way to remove it would be much appreciated.
Old Dec 4, 2006 | 11:05 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
May want to give a shout over in the Tech Forum, plus heres a TTT for you.
Old Dec 4, 2006 | 12:06 PM
NEVERL8C5's Avatar
NEVERL8C5
I did mine this summer and the only way was to remove the water pump. There isn't enough room to go any other way that I know of.
Old Dec 4, 2006 | 12:26 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
I think you're going to have to remove the waterpump....I mean otherwise there might be enough room if you remove your exhaust and passenger side head.
Old Dec 4, 2006 | 12:27 PM
myk7's Avatar
myk7
Replaced mine too a month or so ago... had to remove the water pump. It teased me, sure looked like it would come out without removing the water pump.
To Help removing the AC Compressor
