Odometer is turning over about 88k mi and the suspension as mushy as I'd like it to be...
I've swapped to Bilstein HD's before on a '95 TransAm and the difference was amazing. I'm planning on doing the same for the Vette but am aware that there are the HD's and the Sports.
Now, I'd love to rid some wheel gap but I drive this car 25k mi every year, everywhere, and ground clearance is already an issue at stock height.
My questions:
1) Would lowering an about an inch on the stock bolts create a lot more clearance issues than I already have? Or about the same; therefore, "go ahead and lower the car!"
2) If I keep it at stock height, should I opt for the HD's and not the Sports?
If you lower it, I can't see how it would not cause more problems if you are already having them at the stock height. I'd be very wary of lowering it any more.
I didn't lower my Z because I don't want to drag the rubber piece any more than I already do. Plus I don't want the ride stiffer because during take off the weight wont transfer to the wheels like It would with a stock suspension setting & I would get less traction. Thats just my feelings about It though. I do think lowering my car would make It look alot better, as It would narrow the large gap In the wheel well.
Lowering it an inch is not really that much and the look is worth it. I did mine and I don't scrape anymore than it did before. With the sports your ride will be a little stiffer so this helps too.
my front frame rails and air dam take enough scrapage already at 1 mph entrances and exits at angles, of course. all sorts of crazy driveways around the greater los angeles area...
The Bilstein H-D are nearly OEM stiffness and same length. They are offered as a general service item to restore stock base line ride qualities. The Bilstein Sports are valved stiffer for better handling, AND are a bit shorter to accomidate both stock ride height and lowered cars.with no risk of bottoming out the fluid damper piston in the tube.
Buy the Sports, not the H-D. Adjust your ride height to suit your roads, aesthetics, and handling needs. I had mine pretty slammed low , but raised it back up a bit because I was really banging up the underside. I have ZO6 springs, and found that the max 'lowering on stock bolts' did not go as low as the softer stock springs, After installing the ZO6 springs, I ended up with the Zo6 adjustmemts at the max lowered settings, which is still an inch lower than stock and almost an inch higher than the soft stock spring can go adjusted low on stock bolts.
... Buy the Sports, not the H-D. Adjust your ride height to suit your roads, aesthetics, and handling needs. I had mine pretty slammed low , but raised it back up a bit because I was really banging up the underside. I have ZO6 springs, and found that the max 'lowering on stock bolts' did not go as low as the softer stock springs, After installing the ZO6 springs, I ended up with the Zo6 adjustmemts at the max lowered settings, which is still an inch lower than stock and almost an inch higher than the soft stock spring can go adjusted low on stock bolts.
good luck!
Thanks, I had read that the Sports were recommended for lowered cars only, but it sounds like I can run them at stock height if I choose to? Good point about the springs; I have a Z51 equipped '00 FRC, so a 1'' drop = how many turns of the bolts? Lowering the front/back the same amount to keep the rake
FYI - Lowered on stock bolts and went with the Bilstein Sports. Aligned to stock specs. I am EXTREMELY pleased with the results! The car is a beast; completely different cornering machine!
Also got A&A frame savers and rocker rails, and I use them a LOT. Great piece of mind.
