Part Two 6pt Wolfe Roll Cage Install
Day one of the install for those that have not visited the ripping apart a perfect Vette to put in some well needed safety equipment
http://forums.corvetteforum.com/show....php?t=1565160
Day two went so much smoother than day one of the install. Today GotJuice? cut the rear bars 1 3/8" so they would fit to the rear hatch area and more welding was required
Welding the rear bars
Drivers Side Swing out bar installed
Passanger Side Swing out bar installed
See were some of the welds on the main cage were made
Drivers side carpet test fit
What is left on this job now? We test fit all of the steel reinforcement plates to insure the cage and the swing outs fit like they should. So this bar is a modified Z06 cage confirmed today by GotJuice? from the individual he got it from, this is the reason for all the modifications to make it fit. Next is to clean up the cage and get it painted before we do the final install. Also going to get my drivers side bolster fixed, or I may order some new seat skins, but removing the seats is a snap compared to the work that transpired in the last 2 days. Another benefit of the roll cage was I had the dreaded rocking seats and that will be no more
While GotJuice? was busy welding and drilling holes I put on some bling
, chrome screws around the entire car 46 of them and here is one shot of them that go behind the head lights and also the Black Cherry front markers are installed waiting for an evening for complete night shots of the entire blackout kit I got last month and never finished as my car had a power steering pulley break first and while this was changed was a great time to put in the roll bar
EDIT to correct typo, TRUNK not TRUCK
I have been interested in installing a 4 point bar in mine for some time. Can you supply some photo details and verbage about cutting through the fiberglass panels to gain acess to weldable steel framing, both on the bulkhead behind the seats, and in the TRUNK area pan???? Pretty Please!
What kind of clearance or cantact is there between the glass/plastic body shell and steel at the bulkhead, and the main frame rails in the trunk area?
LOOKING GOOD!!!!!! Nice install, and a great adddition to the car.
Jennifer
Jennifer
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Nice install
Do not like the Wolf mounting points (plate sandwiched and welded to frame) but looks
She's coming along nicely. Great job you are doing.
Originally Posted by FiberglassFan
I have been interested in installing a 4 point bar in mine for some time. Can you supply some photo details and verbage about cutting through the fiberglass panels to gain acess to weldable steel framing, both on the bulkhead behind the seats, and in the truck pan???? Pretty Please!
Jennifer
Jennifer
St. Jude Donor '05-'06-'08
Hey Steve, I guess you got tired of watching me take 1st. places at the car shows........Dont worry, I got some bling coming too.
Car is looking good................
.. looks like a very professional job going on there...
Thanks for documenting it all. Thanks for the teaser pic of the cherry led blackouts too.
